05-09-2013 05:29 PM - edited 03-19-2019 06:43 AM
I had a question about nailing up a cisco voice gateway such as a 2911 as an H323 or MGCP gateway when you plan to do E-SRST failover and will be using the new SRST Manager server.
So is it better to use H323 as the GW control protocol when you are doing E-SRST or does MGCP also work fine in that situation? Before if you were doing CME fallback it seemed best to use H323 so not sure in the new case using E-SRST and the manager server.
thanks
bill
Solved! Go to Solution.
05-10-2013 06:01 AM
My personal opinion is to never use MGCP as it is prone to defects, issues, etc. It makes even more sense not to use it at remote locations requiring SRST as you need to build H323 fallback anyway (dial-peers, etc), so that kind of defeats the purpose.
HTH,
Chris
05-10-2013 06:01 AM
HTH,
Chris
05-10-2013 07:45 AM
Hi Chris
Thanks for the reponse. I was wondering though when using E-SRST if the SRST manger server will still push configs to the router though no matter if you are using MGCP and H323? Before to get CME fallback and such you had to use H323 but with the advent of E-SRST will configs get pushed to the router even though you are using MGCP?
thanks
