help in icd.aef scripting
yaser.nss
hi,
i have a problem in scripting chapter 7 icd.aef, i don;t know how to connect the select resource to agents in order to put the caller in queue:
http://www.uccx.net/wp-content/uploads/2013/08/UCCX%20CRS%20Script%20Editor%20Reference%20Guide%20v1%208.0.1.pdf
Aaron Harrison
Perhaps describe what you have done, and where you are stuck.
Basically a 'select resource' step refers to the name of a CSQ; this is case sensitive and must be exact.
So you must first create a CSQ; assign a skill (or resource group) to it, and assign that skill or RG to an agent.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Aaron Harrison
Aaron
before i tried without creating CSQ name which I've failed, but after digging up i did find this blog
http://blog.ine.com/tag/uccx/
which might be helpful.
am trying to apply it but when i stuck i will be back
Thanks for reply
Hi Aaron,
have have this problem
https://supportforums.cisco.com/discussion/10928771/cannot-connect-ip-phone-agent-service
i did try to restart IPPASvr.exe but useless your help please.
Thanks in advance
the problem is solved,
Thanks Aaron
