Help required with Voice lab
christophermann
I wonder if somebody could solve this mystery for me. I am attempting to set up a Voice Home lab,but have run into an issue at the first hurdle
i have a 2950 12 port switch, that i have set up voice and data vlans on ( see config below) with int fa0/9 set as a trunk.
i also have a 2801 router set as the DHCP router and set as router on a stick to route between the two vlans ( see configs below)
i also have CUCM installed on a dell pc running on VMware. (the inferace for CUCM has an ip address of 192.168.1.14) and the physical interface on the pc is 192.168.1.16.
i also have a 7960 ip phone and cisco ip communicator to start things off with.
the problem i have is that the phone is unable to register at this time with CUCM.
As the it stands at the moment i am able to ping CUCM from the router, however i am unable to ping the router from the switch, and this is where i think the issue lies as there doesnt seem to be an connectivity between the phone and CUCM.
The phone and pc seem to be getting to the DHCP ok as they both have allocated the correct addresses from the address pools set up on the router.
I have torn this down several times now over the last couple of months but am still unable to get any further.
Any assistance that could be provided would be welcomed...i will keep trying..
Kind regards
Chris
Router config
sh run
Building configuration...
Current configuration : 1334 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1 192.168.1.10
ip dhcp excluded-address 192.168.2.1 192.168.2.10
ip dhcp pool VOICE
   network 192.168.2.0 255.255.255.0
   option 150 ip 192.168.1.14
   default-router 192.168.1.14
ip dhcp pool DATA
   network 192.168.1.0 255.255.255.0
no ip domain lookup
voice-card 0
interface FastEthernet0/0
description VOICE_INTERFACE
no ip address
speed 100
full-duplex
interface FastEthernet0/0.10
description DATA_INTERFACE
encapsulation dot1Q 10
no snmp trap link-status
interface FastEthernet0/0.50
encapsulation dot1Q 50
ip address 192.168.2.1 255.255.255.0
interface FastEthernet0/1
no ip address
speed 100
full-duplex
ip http server
no ip http secure-server
control-plane
--More--                           !
line con 0
line aux 0
line vty 0 4
login
end
Switch Config
Current configuration : 1786 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
ip subnet-zero
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
switchport access vlan 10
switchport mode access
switchport voice vlan 50
spanning-tree portfast
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
switchport mode trunk
speed 100
duplex full
interface FastEthernet0/10
duplex full
interface FastEthernet0/11
interface FastEthernet0/12
interface Vlan1
ip address 192.168.1.4 255.255.255.0
ip helper-address 192.168.1.1
no ip route-cache
ip default-gateway 192.168.1.1
ip http server
line con 0
line vty 5 15
end
Switch
Chris Deren
SO, what IP address is the phone getting? Is the getting TFTP option?
I see that on the switch you defined Vlan1 interface with subnet that overlaps with vlan10, it appears you want to use VLAN 10 as your native VLAN and not VLAN1, you may also want to defined interface vlan 50 on your switch with proper ip address and vlan helper.
Also, in your switch config I dont see VLAN 10 and 50 defined.
Chris
Chris,
thanks for your reply. Are you saying make vlan 10 the native vlan?
i have created the vlans 10 and 50 and are present when i show vlan brief?
Just as an asside, if i plug the phone into int fa/12 on the swith it gets a data ip address (192.168.1.12) and registers with CUCM on vlan 1
could you explain what you mean by defining vlan 10 and 50?
Chris
