Help with phone not using correct locale settings for language from CUCM 11.5
Per Hultman
I have a installation of CUCM 11.5 and 7941G phones and i cant get them to use to language installed and choosen in CUCM instead they use the locale language on the phone "english", i want swedish.
I have installed the locale file fom internet
I have chosen to use swedish as the user locale setting globaly, on the device, on the device profile and all the other places i could possible find.
Any advice?
Thanks in advance for any help.
Kind regards.
Per Hultman
pwenger
Level 3
Level 3
Hello Per
What locale you installed the one for the phone or the one for the CUCM? Install both of them.
locale for the phone: https://software.cisco.com/download/home/280083379/type/282074291/os/Linux/release/9.3(4)
locale for CUCM: https://software.cisco.com/download/home/286306100/type/282074333/release/11.5(1.6000)
Hope this helps
Peter
pwenger
Level 3
Level 3
Hello Per
Hope this helps
Peter
Oh i did not know about the phone specific locale installer thanks a lot. However it seems only version 10.1 by engineering custom is available not anything for 11.5 i guess i have to contact Cisco and see if they can put together a Engineering Special for 11.5..
Thanks again Peter.
/Per
