06-16-2010 04:03 AM
If i order a Workspace Licensing Entry Edition for 200 users knowing that CUWL offers for every user 9 DLUs, can i use the rest of unused DLU to connect other phones users?
06-16-2010 04:26 AM
No you cannot and is violation of licensing rules. Every user must be licensed. If a user has multiple phones then they need to be pro. Things will work for now but when cisco enforces user licensing in 9.x you will have issues hence it is best to stick by the rules
Srini
06-16-2010 04:43 AM
Thanks Srini for your replay,
But i want to khow if it's technicaly possible to do it, i want to add just some phones (30) until the new licenses arrives
06-16-2010 04:57 AM
Yes technically it is possible since it is DLU in the backend as I had mentioned above. But it is a violation of licensing rules
Srini
07-02-2010 05:18 PM
DLUs are something of the past. In future releases they will be gone in version 9.(maybe)
UCL and CUWL have replaced DLUs.
When you upgrade in the future UCL and CUWL will be tracked.
