How do I make a new DID range of numbers work?
smashson
I've just been tasked with adding newly acquired numbers to our phone system.  I have very little to no experience with CUCM and need as much help as I can get.  I know you will need more information so please let me know and I will provide it.  Any help would be greatly appreciated.
36 Replies 36
You need to be more specific, were you unable to obtain the debug or unable to attach to this post?
User Access Verification
Password:
LindenVG>enable
Password:
LindenVG#debug isdn q931 5512562512
% Invalid input detected at '^' marker.
LindenVG#
Am I entering it wrong?
You do not include the number in the debug, I needed the number to know what to look for in the log. Simply issue "debug isdn q931",  also do "term mon" before the debug so that you can see the messages come through the terminal.  Once you collect full log (make sure your buffer is set to get it all on your ssh/telnet app) issue "u all" to disable the debug.
How do I know when the debug isdn q931 is finished collecting the full log? Did I enter the commands correctly?
Password:
LindenVG>enable
Password:
LindenVG#term mon
debug isdn q931 is ON.
LindenVG#
Oct 2 14:27:51.833: ISDN Se0/1/1:23 Q931: TX -> DISCONNECT pd = 8 callref = 0xED14
Cause i = 0x8090 - Normal call clearing
Oct 2 14:27:52.098: ISDN Se0/1/1:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x1114
Cause i = 0x8AFF - Interworking error; unspecified
Oct 2 14:27:52.117: ISDN Se0/1/1:23 Q931: TX -> RELEASE pd = 8 callref = 0x9114
Oct 2 14:27:52.149: ISDN Se0/1/1:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x1114
Oct 2 14:27:52.372: ISDN Se0/1/1:23 Q931: RX <- RELEASE pd = 8 callref = 0x6D14
Oct 2 14:27:52.378: ISDN Se0/1/1:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xED14
LindenVG#
Oct 2 14:27:54.111: ISDN Se0/1/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0xCE87
Oct 2 14:27:54.651: ISDN Se0/1/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x4E87
Oct 2 14:27:54.657: ISDN Se0/1/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xCE87
LindenVG#
Oct 2 14:27:56.458: ISDN Se0/1/0:23 Q931: TX -> SETUP pd = 8 callref = 0x2369
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98395
Exclusive, Channel 21
Facility i = 0x9F8B0100A10F02010106072A8648CE1500040A0100
Protocol Profile = Networking Extensions
0xA10F02010106072A8648CE1500040A0100
Component = Invoke component
Invoke Id = 1
Operation = InformationFollowing (calling_name)
Name information in subsequent FACILITY message
Calling Party Number i = 0x2183, '2014208950'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '12013392773'
Oct 2 14:27:56.501: ISDN Se0/1/0:23 Q931: RX <- STATUS pd = 8 callref = 0xA369
Cause i = 0x82E46C - Invalid information element contents
Call State i = 0x01
Oct 2 14:27:56.709: ISDN Se0/1/0:23 Q931: RX <- SETUP pd = 8 callref = 0x4F87
Bearer Capability i = 0x9090A2
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Channel ID i = 0xA1838A
Preferred, Channel 10
Invoke Id = 1
Progress Ind i = 0x8281 - Call not end-to-end ISDN, may have in-band info
LindenVG#0x2183, '4152463854'
Called Party Number i = 0x80, '2012096700'
Plan:Unknown, Type:Unknown
Oct 2 14:27:56.711: ISDN Se0/1/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0xA369
Oct 2 14:27:56.719: ISDN Se0/1/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0xCF87
Channel ID i = 0xA9838A
Exclusive, Channel 10
Oct 2 14:27:56.743: ISDN Se0/1/0:23 Q931: TX -> ALERTING pd = 8 callref = 0xCF87
Progress Ind i = 0x8088 - In-band info or appropriate now available
Oct 2 14:27:56.761: ISDN Se0/1/0:23 Q931: TX -> CONNECT pd = 8 callref = 0xCF87
Oct 2 14:27:56.790: ISDN Se0/1/0:23 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x4F87
LindenVG#
Oct 2 14:27:57.079: ISDN Se0/1/0:23 Q931: RX <- FACILITY pd = 8 callref = 0x4F87
Facility i = 0x9F8B0100A117020101020100800F57415249415241204C594E4E202020
0xA117020101020100800F57415249415241204C594E4E202020
Invoke Id = 1
Operation = CallingName
Name Presentation Allowed Extended
Name = WARIARA LYNN
Oct 2 14:27:57.956: ISDN Se0/1/0:23 Q931: RX <- ALERTING pd = 8 callref = 0xA369
Progress Ind i = 0x8488 - In-band info or appropriate now available
LindenVG#
Oct 2 14:27:58.468: ISDN Se0/1/0:23 Q931: TX -> FACILITY pd = 8 callref = 0x2369
Facility i = 0x9F8B0100A1080201010201008400
0xA1080201010201008400
Invoke Id = 1
Name not available
Oct 2 14:27:59.509: ISDN Se0/1/0:23 Q931: RX <- SETUP pd = 8 callref = 0x5087
Standard = CCITT
Channel ID i = 0xA1838B
Preferred, Channel 11
Invoke Id = 1
LindenVG#
Calling Party Number i = 0x2183, '7328283000'
Oct 2 14:27:59.525: ISDN Se0/1/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0xD087
Channel ID i = 0xA9838B
Exclusive, Channel 11
Oct 2 14:27:59.573: ISDN Se0/1/0:23 Q931: TX -> ALERTING pd = 8 callref = 0xD087
Oct 2 14:27:59.594: ISDN Se0/1/0:23 Q931: TX -> CONNECT pd = 8 callref = 0xD087
Oct 2 14:27:59.620: ISDN Se0/1/0:23 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x5087
LindenVG#
Oct 2 14:27:59.824: ISDN Se0/1/0:23 Q931: RX <- FACILITY pd = 8 callref = 0x5087
Facility i = 0x9F8B0100A117020101020100800F524F4245525420574F4F44204A4F48
0xA117020101020100800F524F4245525420574F4F44204A4F48
Invoke Id = 1
Name = ROBERT WOOD JOH
LindenVG#
Oct 2 14:28:01.481: ISDN Se0/1/0:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x4787
Oct 2 14:28:01.498: ISDN Se0/1/0:23 Q931: TX -> RELEASE pd = 8 callref = 0xC787
Oct 2 14:28:01.526: ISDN Se0/1/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x4787
LindenVG#
Oct 2 14:28:08.912: ISDN Se0/1/0:23 Q931: TX -> SETUP pd = 8 callref = 0x236A
Standard = CCITT
Channel ID i = 0xA98393
Exclusive, Channel 19
Facility i = 0x9F8B0100A1190201010201008011436172656E61204D696C65732035323839
0xA1190201010201008011436172656E61204D696C65732035323839
Invoke Id = 1
Name = Carena Miles 5289
Display i = 'Carena Miles 5289'
LindenVG# i = 0x2181, '2015475289'
Called Party Number i = 0xA1, '2012896797'
Oct 2 14:28:09.086: ISDN Se0/1/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0xA36A
LindenVG#
Oct 2 14:28:11.287: ISDN Se0/1/1:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x6B14
Oct 2 14:28:11.304: ISDN Se0/1/1:23 Q931: TX -> RELEASE pd = 8 callref = 0xEB14
Oct 2 14:28:11.335: ISDN Se0/1/1:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x6B14
Oct 2 14:28:11.861: ISDN Se0/1/0:23 Q931: RX <- PROGRESS pd = 8 callref = 0xA36A
Oct 2 14:28:12.061: ISDN Se0/1/0:23 Q931: RX <- PROGRESS pd = 8 callref = 0xA36A
LindenVG#
Oct 2 14:28:12.271: ISDN Se0/1/0:23 Q931: RX <- ALERTING pd = 8 callref = 0xA36A
LindenVG#
Oct 2 14:28:14.044: ISDN Se0/1/0:23 Q931: RX <- SETUP pd = 8 callref = 0x5187
Standard = CCITT
Channel ID i = 0xA9838E
Exclusive, Channel 14
Invoke Id = 1
Calling Party Number i = 0x2183, '5514041825'
Called Party Number i = 0x80, '2015475538'
Oct 2 14:28:14.064: ISDN Se0/1/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0xD187
Oct 2 14:28:14.092: ISDN Se0/1/0:23 Q931: TX -> ALERTING pd = 8 callref = 0xD187
Oct 2 14:28:14.120: ISDN Se0/1/0:23 Q931: TX -> CONNECT pd = 8 callref = 0xD187
Oct 2 14:28:14.141: ISDN Se0/1/0:23 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x5187
LindenVG#
Oct 2 14:28:14.545: ISDN Se0/1/0:23 Q931: RX <- FACILITY pd = 8 callref = 0x5187
Facility i = 0x9F8B0100A117020101020100800F424552424552414245204C494C5942
0xA117020101020100800F424552424552414245204C494C5942
Invoke Id = 1
Name = BERBERABE LILYB
LindenVG#
Oct 2 14:28:17.906: ISDN Se0/1/0:23 Q931: RX <- CONNECT pd = 8 callref = 0xA36A
Oct 2 14:28:17.908: ISDN Se0/1/0:23 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x236A
Oct 2 14:28:18.165: ISDN Se0/1/1:23 Q931: RX <- SETUP pd = 8 callref = 0x7814
Standard = CCITT
Channel ID i = 0xA18384
Preferred, Channel 4
Invoke Id = 1
Calling Party Number i = 0x2183, '7324306417'
Oct 2 14:28:18.177: ISDN Se0/1/1:23 Q931: TX -> CALL_PROC pd = 8 callref = 0xF814
Channel ID i = 0xA98384
Exclusive, Channel 4
Oct 2 14:28:18.199: ISDN Se0/1/1:23 Q931: TX -> ALERTING pd = 8 callref = 0xF814
Oct 2 14:28:18.221: ISDN Se0/1/1:23 Q931: TX -> CONNECT pd = 8 callref = 0xF814
Oct 2 14:28:18.246: ISDN Se0/1/1:23 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x7814
Oct 2 14:28:18.465: ISDN Se0/1/1:23 Q931: RX <- FACILITY pd = 8 callref = 0x7814
Facility i = 0x9F8B0100A113020101020100800B424849524F20414D524954
0xA113020101020100800B424849524F20414D524954
Invoke Id = 1
LindenVG#
Name = BHIRO AMRIT
LindenVG#
Oct 2 14:28:20.227: ISDN Se0/1/1:23 Q931: TX -> SETUP pd = 8 callref = 0x4E76
Standard = CCITT
Channel ID i = 0xA98396
Exclusive, Channel 22
Facility i = 0x9F8B0100A117020101020100800F4C616B6872616D20426173616E7461
0xA117020101020100800F4C616B6872616D20426173616E7461
Invoke Id = 1
Name = Lakhram Basanta
Display i = 'Lakhram Basanta'
LindenVG# i = 0x2181, '2015475766'
Called Party Number i = 0xA1, '18005754433'
Oct 2 14:28:20.542: ISDN Se0/1/1:23 Q931: RX <- CALL_PROC pd = 8 callref = 0xCE76
Oct 2 14:28:21.218: ISDN Se0/1/1:23 Q931: TX -> SETUP pd = 8 callref = 0x4E77
Standard = CCITT
Channel ID i = 0xA98394
Exclusive, Channel 20
Facility i = 0x9F8B0100A11D0201010201008015436861726C6573204A6F686E73746F6E2033323831
0xA11D0201010201008015436861726C6573204A6F686E73746F6E2033323831
Invoke Id = 1
Name = Charles Johnston 3281
Display i = 'Charles Johnston 3281'
Calling Party Number i = 0x2181, '2015475003'
Called Party Number i = 0xA1, '2019946653'
Oct 2 14:28:21.276: ISDN Se0/1/1:23 Q931: RX <- SETUP pd = 8 callref = 0x7914
Standard = CCITT
Invoke Id = 1
Progress Ind i = 0x8483 - Origination address is non-ISDN
Calling Party Number i = 0x2181, '7322974847'
Calling Party Number i = 0x2183, '1473210924'
Called Party Number i = 0x80, '2015474469'
Oct 2 14:28:21.288: ISDN Se0/1/1:23 Q931: TX -> CALL_PROC pd = 8 callref = 0xF914
Oct 2 14:28:21.288: ISDN Se0/1/1:23 Q931: TX -> ALERTING pd = 8 callref = 0xF914
Oct 2 14:28:21.397: ISDN Se0/1/1:23 Q931: RX <- CALL_PROC pd = 8 callref = 0xCE77
LindenVG#
Oct 2 14:28:21.505: ISDN Se0/1/1:23 Q931: RX <- FACILITY pd = 8 callref = 0x7914
Facility i = 0x9F8B0100A115020101020100800D47575320454E5649524F4E4D45
0xA115020101020100800D47575320454E5649524F4E4D45
Invoke Id = 1
Name = GWS ENVIRONME
Oct 2 14:28:21.785: ISDN Se0/1/1:23 Q931: RX <- SETUP pd = 8 callref = 0x7A14
Standard = CCITT
Channel ID i = 0xA1838C
Preferred, Channel 12
Invoke Id = 1
Calling Party Number i = 0x2183, '5162256561'
Called Party Number i = 0x80, '2015475055'
Oct 2 14:28:21.797: ISDN Se0/1/1:23 Q931: TX -> CALL_PROC pd = 8 callref = 0xFA14
Channel ID i = 0xA9838C
Exclusive, Channel 12
Oct 2 14:28:21.903: ISDN Se0/1/1:23 Q931: TX -> ALERTING pd = 8 callref = 0xFA14
Oct 2 14:28:21.942: ISDN Se0/1/1:23 Q931: RX <- PROGRESS pd = 8 callref = 0xCE76
Progress Ind i = 0x8481 - Call not end-to-end ISDN, may have in-band info
Oct 2 14:28:22.201: ISDN Se0/1/0:23 Q931: RX <- CONNECT pd = 8 callref = 0xA369
LindenVG#
Oct 2 14:28:22.204: ISDN Se0/1/0:23 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x2369
Oct 2 14:28:22.205: ISDN Se0/1/1:23 Q931: RX <- FACILITY pd = 8 callref = 0x7A14
Facility i = 0x9F8B0100A117020101020100800F574952454C4553532043414C4C4552
0xA117020101020100800F574952454C4553532043414C4C4552
Invoke Id = 1
Name = WIRELESS CALLER
Oct 2 14:28:22.812: ISDN Se0/1/1:23 Q931: RX <- PROGRESS pd = 8 callref = 0xCE77
LindenVG#
Oct 2 14:28:23.802: ISDN Se0/1/1:23 Q931: RX <- CONNECT pd = 8 callref = 0xCE76
Progress Ind i = 0x8A82 - Destination address is non-ISDN
Oct 2 14:28:23.805: ISDN Se0/1/1:23 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x4E76
LindenVG#
Oct 2 14:28:25.117: ISDN Se0/1/1:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x7A14
Cause i = 0x8490 - Normal call clearing
Oct 2 14:28:25.135: ISDN Se0/1/1:23 Q931: TX -> RELEASE pd = 8 callref = 0xFA14
Oct 2 14:28:25.162: ISDN Se0/1/1:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x7A14
Oct 2 14:28:25.350: ISDN Se0/1/1:23 Q931: TX -> DISCONNECT pd = 8 callref = 0xF814
Oct 2 14:28:25.902: ISDN Se0/1/1:23 Q931: RX <- RELEASE pd = 8 callref = 0x7814
Oct 2 14:28:25.907: ISDN Se0/1/1:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xF814
Oct 2 14:28:26.117: ISDN Se0/1/1:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x7314
Oct 2 14:28:26.143: ISDN Se0/1/1:23 Q931: TX -> RELEASE pd = 8 callref = 0xF314
Oct 2 14:28:26.172: ISDN Se0/1/1:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x7314
Oct 2 14:28:26.260: ISDN Se0/1/1:23 Q931: RX <- SETUP pd = 8 callref = 0x7B14
Standard = CCITT
Invoke Id = 1
Calling Party Number i = 0x2183, '2017445664'
Called Party Number i = 0x80, '2015474745'
Oct 2 14:28:26.274: ISDN Se0/1/1:23 Q931: TX -> CALL_PROC pd = 8 callref = 0xFB14
LindenVG#
Oct 2 14:28:26.274: ISDN Se0/1/1:23 Q931: TX -> ALERTING pd = 8 callref = 0xFB14
Oct 2 14:28:26.636: ISDN Se0/1/0:23 Q931: RX <- DISCONNECT pd = 8 callref = 0xA369
Oct 2 14:28:26.648: ISDN Se0/1/0:23 Q931: TX -> RELEASE pd = 8 callref = 0x2369
Oct 2 14:28:26.671: ISDN Se0/1/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0xA369
Oct 2 14:28:26.885: ISDN Se0/1/1:23 Q931: RX <- FACILITY pd = 8 callref = 0x7B14
Facility i = 0x9F8B0100A117020101020100800F5345525241544F2043455341522020
0xA117020101020100800F5345525241544F2043455341522020
Invoke Id = 1
Name = SERRATO CESAR
Oct 2 14:28:27.197: ISDN Se0/1/1:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x4E74
Cause i = 0x8A90 - Normal call clearing
Oct 2 14:28:27.737: ISDN Se0/1/1:23 Q931: RX <- RELEASE pd = 8 callref = 0xCE74
LindenVG#
Oct 2 14:28:27.743: ISDN Se0/1/1:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x4E74
LindenVG#
Oct 2 14:28:29.190: ISDN Se0/1/1:23 Q931: TX -> CONNECT pd = 8 callref = 0xFB14
Display i = 'Sonia Dublin - 4745'
Oct 2 14:28:29.217: ISDN Se0/1/1:23 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x7B14
Oct 2 14:28:29.929: ISDN Se0/1/0:23 Q931: RX <- SETUP pd = 8 callref = 0x5287
Standard = CCITT
Invoke Id = 1
Oct 2 14:28:29.947: ISDN Se0/1/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0xD287
Oct 2 14:28:30.014: ISDN Se0/1/0:23 Q931: TX -> ALERTING pd = 8 callref = 0xD287
Oct 2 14:28:30.304: ISDN Se0/1/0:23 Q931: RX <- FACILITY pd = 8 callref = 0x5287
Invoke Id = 1
Oct 2 14:28:30.310: ISDN Se0/1/1:23 Q931: RX <- SETUP pd = 8 callref = 0x7C14
Standard = CCITT
Channel ID i = 0xA18385
Preferred, Channel 5
Invoke Id = 1
Calling Party Number i = 0x2183, '3478852850'
Oct 2 14:28:30.323: ISDN Se0/1/1:23 Q931: TX -> CALL_PROC pd = 8 callref = 0xFC14
Channel ID i = 0xA98385
Exclusive, Channel 5
Oct 2 14:28:30.347: ISDN Se0/1/1:23 Q931: TX -> ALERTING pd = 8 callref = 0xFC14
Oct 2 14:28:30.367: ISDN Se0/1/1:23 Q931: TX -> CONNECT pd = 8 callref = 0xFC14
Oct 2 14:28:30.397: ISDN Se0/1/1:23 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x7C14
LindenVG#
Oct 2 14:28:30.445: ISDN Se0/1/1:23 Q931: RX <- FACILITY pd = 8 callref = 0x7C14
Facility i = 0x9F8B0100A117020101020100800F42524F4F4B4C594E20202020204E59
0xA117020101020100800F42524F4F4B4C594E20202020204E59
Invoke Id = 1
Name = BROOKLYN NY
LindenVG#
Oct 2 14:28:33.702: ISDN Se0/1/1:23 Q931: RX <- CONNECT pd = 8 callref = 0xCE77
Oct 2 14:28:33.708: ISDN Se0/1/1:23 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x4E77
Oct 2 14:28:34.420: ISDN Se0/1/0:23 Q931: TX -> CONNECT pd = 8 callref = 0xD287
Display i = 'Construction Code'
Oct 2 14:28:34.451: ISDN Se0/1/0:23 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x5287
LindenVG#
Oct 2 14:28:34.808: ISDN Se0/1/1:23 Q931: TX -> SETUP pd = 8 callref = 0x4E78
Standard = CCITT
Channel ID i = 0xA98397
Exclusive, Channel 23
Facility i = 0x9F8B0100A11A02010102010080125A756C6D61204C616D656C612D2034373433
0xA11A02010102010080125A756C6D61204C616D656C612D2034373433
Invoke Id = 1
Name = Zulma Lamela- 4743
Display i = 'Zulma Lamela- 4743'
LindenVG# i = 0x2181, '2015474743'
Called Party Number i = 0xA1, '12018874790'
Oct 2 14:28:35.022: ISDN Se0/1/1:23 Q931: RX <- CALL_PROC pd = 8 callref = 0xCE78
LindenVG#
Oct 2 14:28:37.715: ISDN Se0/1/1:23 Q931: RX <- SETUP pd = 8 callref = 0x7D14
Standard = CCITT
Invoke Id = 1
LindenVG#
Calling Party Number i = 0x2183, '2672503942'
Oct 2 14:28:37.726: ISDN Se0/1/1:23 Q931: TX -> CALL_PROC pd = 8 callref = 0xFD14
Oct 2 14:28:37.750: ISDN Se0/1/1:23 Q931: TX -> ALERTING pd = 8 callref = 0xFD14
Oct 2 14:28:37.770: ISDN Se0/1/1:23 Q931: TX -> CONNECT pd = 8 callref = 0xFD14
Oct 2 14:28:37.798: ISDN Se0/1/1:23 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x7D14
LindenVG#
Oct 2 14:28:38.285: ISDN Se0/1/1:23 Q931: RX <- FACILITY pd = 8 callref = 0x7D14
Facility i = 0x9F8B0100A117020101020100800F534D4954482054484F4D4153202020
0xA117020101020100800F534D4954482054484F4D4153202020
Invoke Id = 1
Name = SMITH THOMAS
Oct 2 14:28:38.862: ISDN Se0/1/1:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x7D14
Oct 2 14:28:38.879: ISDN Se0/1/1:23 Q931: TX -> RELEASE pd = 8 callref = 0xFD14
Oct 2 14:28:38.907: ISDN Se0/1/1:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x7D14
Oct 2 14:28:39.182: ISDN Se0/1/1:23 Q931: RX <- PROGRESS pd = 8 callref = 0xCE78
Oct 2 14:28:39.339: ISDN Se0/1/1:23 Q931: TX -> CONNECT pd = 8 callref = 0xF914
Oct 2 14:28:39.362: ISDN Se0/1/1:23 Q931: RX <- PROGRESS pd = 8 callref = 0xCE78
Oct 2 14:28:39.364: ISDN Se0/1/1:23 Q931: RX <- ALERTING pd = 8 callref = 0xCE78
LindenVG#
Oct 2 14:28:39.366: ISDN Se0/1/1:23 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x7914
Oct 2 14:28:40.231: ISDN Se0/1/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0xC287
Cause i = 0x8093 - User alerting, no answer
LindenVG#
Oct 2 14:28:40.826: ISDN Se0/1/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x4287
Oct 2 14:28:40.832: ISDN Se0/1/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xC287
LindenVG#
Oct 2 14:28:43.389: ISDN Se0/1/1:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x4E78
Oct 2 14:28:43.426: ISDN Se0/1/1:23 Q931: RX <- RELEASE pd = 8 callref = 0xCE78
Oct 2 14:28:43.432: ISDN Se0/1/1:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x4E78
Oct 2 14:28:44.174: ISDN Se0/1/0:23 Q931: RX <- SETUP pd = 8 callref = 0x5387
Standard = CCITT
Channel ID i = 0xA98387
Exclusive, Channel 7
Invoke Id = 1
Calling Party Number i = 0x2183, '9083687866'
Oct 2 14:28:44.188: ISDN Se0/1/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0xD387
Oct 2 14:28:44.212: ISDN Se0/1/0:23 Q931: TX -> ALERTING pd = 8 callref = 0xD387
Oct 2 14:28:44.236: ISDN Se0/1/0:23 Q931: TX -> CONNECT pd = 8 callref = 0xD387
Oct 2 14:28:44.261: ISDN Se0/1/0:23 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x5387
Oct 2 14:28:44.464: ISDN Se0/1/0:23 Q931: RX <- FACILITY pd = 8 callref = 0x5387
Facility i = 0x9F8B0100A115020101020100800D4841524D4F4E2057414C544552
0xA115020101020100800D4841524D4F4E2057414C544552
Invoke Id = 1
LindenVG#
Name = HARMON WALTER
Oct 2 14:28:44.831: ISDN Se0/1/0:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x2187
Oct 2 14:28:44.848: ISDN Se0/1/0:23 Q931: TX -> RELEASE pd = 8 callref = 0xA187
Oct 2 14:28:44.871: ISDN Se0/1/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x2187
LindenVG#
Oct 2 14:28:46.338: ISDN Se0/1/0:23 Q931: TX -> SETUP pd = 8 callref = 0x236B
Standard = CCITT
Channel ID i = 0xA98389
Exclusive, Channel 9
Facility i = 0x9F8B0100A122020101020100801A41646D696E6973747261746F727320436F7572742020526D2031
0xA122020101020100801A41646D696E6973747261746F727320436F7572742020526D2031
Invoke Id = 1
Name = Administrators Court Rm 1
Display i =
LindenVG#'Administrators Court Rm 1'
Calling Party Number i = 0x2181, '2012096700'
Called Party Number i = 0xA1, '12018586918'
Oct 2 14:28:46.506: ISDN Se0/1/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0xA36B
LindenVG#
Oct 2 14:28:48.561: ISDN Se0/1/0:23 Q931: RX <- PROGRESS pd = 8 callref = 0xA36B
Oct 2 14:28:48.786: ISDN Se0/1/0:23 Q931: RX <- ALERTING pd = 8 callref = 0xA36B
Oct 2 14:28:49.260: ISDN Se0/1/1:23 Q931: RX <- SETUP pd = 8 callref = 0x7E14
Standard = CCITT
Invoke Id = 1
Calling Party Number i = 0x2183, '2015192587'
Called Party Number i = 0x80, '2014795970'
Oct 2 14:28:49.284: ISDN Se0/1/1:23 Q931: TX -> CALL_PROC pd = 8 callref = 0xFE14
LindenVG#
Oct 2 14:28:49.284: ISDN Se0/1/1:23 Q931: TX -> ALERTING pd = 8 callref = 0xFE14
Oct 2 14:28:49.430: ISDN Se0/1/1:23 Q931: RX <- FACILITY pd = 8 callref = 0x7E14
Invoke Id = 1
LindenVG#
Oct 2 14:28:50.163: ISDN Se0/1/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0xC887
Oct 2 14:28:50.691: ISDN Se0/1/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x4887
Oct 2 14:28:50.699: ISDN Se0/1/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xC887
LindenVG#
Oct 2 14:28:53.989: ISDN Se0/1/0:23 Q931: RX <- SETUP pd = 8 callref = 0x5487
Standard = CCITT
Channel ID i = 0xA98383
Exclusive, Channel 3
Invoke Id = 1
Calling Party Number i = 0x2183, '8625716851'
Oct 2 14:28:54.001: ISDN Se0/1/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0xD487
Oct 2 14:28:54.025: ISDN Se0/1/0:23 Q931: TX -> ALERTING pd = 8 callref = 0xD487
Oct 2 14:28:54.046: ISDN Se0/1/0:23 Q931: TX -> CONNECT pd = 8 callref = 0xD487
Oct 2 14:28:54.071: ISDN Se0/1/0:23 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x5487
LindenVG#
Oct 2 14:28:54.175: ISDN Se0/1/0:23 Q931: RX <- FACILITY pd = 8 callref = 0x5487
Facility i = 0x9F8B0100A117020101020100800F475545525245524F204D494E454C4C
0xA117020101020100800F475545525245524F204D494E454C4C
Invoke Id = 1
Name = GUERRERO MINELL
Oct 2 14:28:54.863: ISDN Se0/1/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x236A
Oct 2 14:28:54.896: ISDN Se0/1/0:23 Q931: RX <- RELEASE pd = 8 callref = 0xA36A
LindenVG#
Oct 2 14:28:54.902: ISDN Se0/1/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x236A
LindenVG#ual
Oct 2 14:28:56.762: ISDN Se0/1/1:23 Q931: TX -> DISCONNECT pd = 8 callref = 0xE614
Oct 2 14:28:57.411: ISDN Se0/1/1:23 Q931: RX <- RELEASE pd = 8 callref = 0x6614
Oct 2 14:28:57.419: ISDN Se0/1/1:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xE614
LindenVG#u all
All possible debugging has been turned off
LindenVG#
LindenVG#User Access Verification
What number did you call as I don't see "5512562512"?
I just wanted to mention that when I call the number from my cell I get the message that the number is not a working number.
Does this mean that the calls to 5512562512 are not even hitting the gateway?
I have to run to a meeting. I just wanted to thank you for all your help thus far and I hope that you can continue to help me until this gets solved.
Correct, it appears calls are delivered to these PRIs with 10 digits and none in the traces match the number you provided, perhaps the call arrives via another GW.  Assuming the numbers arrive via 10 digits and no translation is done on GW (you cannot do that with MGCP) then if your DNs are 4 digits on the phone you need to have proper translation pattern that strips first 6 digits, make sure this TP is in partition listed in the gateway's calling search space and make sure this TP has CSS assigned that can reach the phone DN partition.
Ok. So my TP should look something like 551256.25XX? I feel like I’m missing a key element though.
Yes, assuming your partitions and CSSes are correct as I described.
Is it possible this would interfere with other TPs?
As long as you put it in partition that is reachable ONLY from the GW then no, as the only way to reach it would be for calls arriving from this GW.  You should be able to just use the same config of another translation pattern used at this location, and just adjust the pattern.
I’m going to give that a try as soon as I get the chance. I’ve been told that by the telco that these numbers are “active”. Is there anything on the VG I would need to configure regarding the dial plan? Also, could this be a telco issue or it’s 100% based on getting the CUCM config correct?
Since the config you posted is using MGCP protocol to control the PRI there is nothing to be added to the GW, however you should have seen the call when doing the debug isdn q931 if the number was arriving to this GW.  Did you validate you were doing the debug on the correct GW?
