12-26-2017 09:20 PM - edited 03-19-2019 01:01 PM
I have blocked a specific pattern in my cucm 11.x. But the anonymous calls are getting rejected. Created a NONE translation pattern but it doesnt work. I am having a MGCP gateway. Other options i have read to uncheck the (reject anonymous call in the DN option) box. But all the DN's are unchecked already. Any other solution to convert a anonymous call to a generic call so that cucm will accept the calls.
01-24-2018 08:51 AM
05-03-2018 02:14 PM
Hi Dineshshoba,
Unfortunately, if the checkbox for "Reject Anonymous Calls" is checked on the DNs, you will need to uncheck that box in order to receive Anonymous Calls.
An easy way to accomplish this on all phones at once would be to use Bulk Administration in CUCM:
Please note that you may also need to Apply Config to these phones, which can also be done through Bulk Administration.
Dalton Woolsey
