How to get my own SIP-URI?
Shams Rishad
I have setup two Telepresence codecs and each can call the other using SIP protocol by dialing the IP assigned. But I have seen people have SIP-URIs like sip:abc@pqr.xyz. How do I get/create my own SIP-URI?
Rishad
Hi Shams,
May I know your codec type? Is it Standalone or register with UCM or VCS/Expressway?
If it is standalone, then the recommended method is to use h323. if you want to use a SIP URI, you need a SIP Registrar server and SIP proxy server.
SIP URI is the SIP alias with the domain name.
Shalid
Hi Shams,
Shalid
