How to get prompt wav file using AvT
mkt.cisco
Dear experts,
I used the AvT on the TUI to record the greeting or prompt.
I'd like to know how I can get the recorded wav file.
I can't find the file in "Voice Mail -> Prompts" on the GUI.
Where is it?
CUE version is 2.3
Thanks in advance.
Rob Huffman
Hi Nor,
Did you Save/Upload the file when you finished recording?
Uploading the Auto-Attendant Greeting or Prompt File
After recording the .wav greeting or prompt file, upload the file using the ccn copy url command in Cisco Unity Express EXEC mode:
ccn copy url source-ip-address prompt prompt-filename
Example:
se-10-0-0-0# ccn copy url ftp://10.100.10.123/AAprompt1.wav prompt AAprompt1.wav
se-10-0-0-0# ccn copy url http://www.server.com/AAgreeting.wav prompt AAgreeting.wav
This command is equivalent to using the GUI option Voice Mail > Prompts and selecting Upload.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel3_0/administration/guide/voicemail/5AAttnd.html#wp1011691
Hope this helps!
Rob
Hi Rob,
Thanks a lot. I had read the manual you pointed out. I think I saved the file correctly. Actually, the original Greeing can be heard. However I can't find the file.
Any helps would be appreciated.
