How to play announcement that call is being recorded to callers
T00722700
I have a customer who is getting Calabrio call recording, but no contact centre.
Some phones will not be recorded
Some phones will always be recorded
Some phones will press record button to initiate call recording
Customer wants callers to hear an announcement that call is being recorded for the phones that are set to automatically record, and ideally want callers to hear an announcement for the phones that selectively press the record button only after they press the record button.
Calabrio said they have no way of playing any announcements, so it must be done on the CUCM or CUC side.
Recorded Phones will receive calls either via the main AA, or directly to their DID.
Some of these DIDs/DNs  have mailboxes.
If I route all the calls thru CUC first to play an announcement, can the extension still have a mailbox in Unity.  If so, how is this configured?
Or is there a better solution to play an announcement then routing calls thru CUC?
thanks!
Michelle
Pranjol Saikia
Level 4
Level 4
Sorry for answering to a very old thread.
Call recording announcement
Site engineers can checkout below 3rd party solution for this kind of requirements ( Play out Call Recording Warning / Announcements )
MARS Agent Greeting :
https://developer.cisco.com/ecosystem/cpp/solutions/181073/
https://www.youtube.com/watch?v=DBFV8m-IfjE
MARS Agent Greeting application for Cisco CUCM / UCCX / UCCE / PCCE can welcome the caller, identify the agent, and include other useful contextual information. Play out a call recording announcement. If the call is being recorded by any call recording application then the "Recording announcement"
CUCM does not have this feature
on CUC, you can define a "Call-Handler" which only plays a "Greeting" and then forward to a Specific Extension to answer..
(in greeting, you play your announcement file)
(for forward to an extension, you must define another Call-Handler, which only his "Alternate" mode is Enabled, and Forwarded to an Extension, then on your Greeting Call-Handler, in action of after play, set to forward to this Alternate enabled Call-Handler..)
or
you can use "imagicle" call recording solution..
it's one of the best partners of cisco products
and they support this feature completely..
https://www.imagicle.com/en/products/call-recording/
(Rate by "Helpful" or "Accept") (محمدرضا هادی_ایران) (Email: morez.hadi@gmail.com)
