Hunt Group members answering calls not getting recorded
jaspreet_mac1
We are currently on CUCM 8.6.
We can see that direct calls from mobile to CIPC BO number is recorded in Verint but if the mobile calls the Hunt Group Pilot number and is answered on CIPC BO same number it is not recorded.
Is there anything need to be checked.
Jaspreet
May be You need to enable Call Recordign on Hunt Pilot Number in Varient Or Try below
https://supportforums.cisco.com/discussion/12288671/hunt-pilot-recording
5 Replies 5
HARIS_HUSSAIN
What recording method are you using Network Based or Using Phone Built In Bridge.
Hunt Pilot number added in varient and working fine . Thanks for your support.
Network Base ...
Built In Bridge is set as default
Hi Guys, our setup is passive recording, switch ports are forwarding traffic to Verint recorder. So adding hunt pilot in Verint will not work because it needs to get CTI event from a mac address of a device to record the call. So is there a way to record hunt pilot in Verint while using Passive Recording ? Any help would be appreciated. Thanks!
