Bookmark
Subscribe
2583
IM and Presence 11.0 Configuration validation failed.
MabonaZA
Problem: IM and Presence 11.0 Configuration validation failed.
Background:
Upgraded cucm 8.6.2 to 11.0.1 successfully.
Decommissioned old CUP server by deleting application sever. I am now trying to configure IMP 11.0.1 on CUCM as follows:
1. System > Server > Add new.
2. entered IP Address of IMP (not using dns).
3. entered domain.
On my VM install I enter all required CUCM information (First node )as require:
1. entered hostname
2. entered IP Address (cucm not using dns)
3. and security password.
...configuration validation failed. "Configured first node not the first node"
CUCM Version: 11.0.1.21900-11
IMP Version: 11.0.1.10000-6
see below steps.
Server
IMP
IMP Address
Warning
First node
validation_failed
admin:show myself
Machine Name : ZAPTACCM01
account name : Administrator
privilege level : 4
command count : disabled
logging setting : disabled
admin:show network cluster
192.168.10.11 ZAPTACCM02 Subscriber callmanager DBSub authenticated using TCP since Mon Jul 4 17:36:01 2016
192.168.10.10 ZAPTACCM01 Publisher callmanager DBPub authenticated
Server Table (processnode) Entries
192.168.10.11
192.168.10.10
192.168.10.21
admin:utils dbreplication runtimestate
Server Time: Wed Jul 6 15:41:46 SAST 2016
Cluster Replication State: Replication status command started at: 2016-07-06-15-41
Replication status command in PROGRESS. Checked 295 tables out of 692
Last Completed Table: codeclist
No Errors or Mismatches found.
Use 'file view activelog cm/trace/dbl/sdi/ReplicationStatus.2016_07_06_15_41_07.out' to see the details
replication
Chris Deren
Perhaps your security password is invalid, are you sure you have it correct?
Chris Deren
I have scheduled downtime for today to change the security password. This is the 3rd upgrade done on the cluster and there was no attempt to a node before since
Will let you know how it goes after security password change.
Yep, It was security password.
Validation passed after resetting security password on cuc pub.
