Importing Users Exchange 2003 Problem
astrohmeier
I have a customer with Exchange2003 /5.5. I installaed Unity 4.0.4 and it runs. If I want to Import a user and I click search for searching AD Users I get an error that the page cannot be displayed.
Importing a user over the Tools Depot is possible.
Achim
tonyw1538
This happened in our environment as well.
If you have the same situation, then you will be able to add users from the Unity server itself, but not from a remote computer.
The solution for us was to add the Unity server to the list of 'trusted' sites in Internet Explorer at the desktop.
thanks for your answer. In my case it dosen´t run anywhere. The only possibility to import users is the Tools depot.
Achim
jrezab
This has been a problem even in early 4.x versions. If you have done a query (magnifiy glass) to query a subscriber by extension, the import new user will fail. Your last query subscriber must be by alias, firstname or lastname, then import will work.
