09-21-2004 01:02 AM - edited 03-18-2019 03:34 PM
I have a customer with Exchange2003 /5.5. I installaed Unity 4.0.4 and it runs. If I want to Import a user and I click search for searching AD Users I get an error that the page cannot be displayed.
Importing a user over the Tools Depot is possible.
Achim
09-21-2004 06:40 AM
This happened in our environment as well.
If you have the same situation, then you will be able to add users from the Unity server itself, but not from a remote computer.
The solution for us was to add the Unity server to the list of 'trusted' sites in Internet Explorer at the desktop.
09-22-2004 01:45 AM
thanks for your answer. In my case it dosen´t run anywhere. The only possibility to import users is the Tools depot.
Achim
09-22-2004 07:50 AM
This has been a problem even in early 4.x versions. If you have done a query (magnifiy glass) to query a subscriber by extension, the import new user will fail. Your last query subscriber must be by alias, firstname or lastname, then import will work.
