Increase VM resource to Unity Connection and Im&Presence
asafgo616
I have Unity Connection and Im&Presence in Ver: 11.5.1.11900
2 Unity Servers and 2 Presence servers.
The VM installed with the resource:
VM CPU Memory Disk Users
Im&Presence 2 vCPU 4 GB 80GB X2 5,000
Unity Connection 1 vCPU 4 GB 160GB 1,000
Now i need to increase the resource to:
Im&Presence 4 vCPU 8 GB 80GB X2 15,000
Unity Connection 2 vCPU 6 GB 200GB 5,000
I saw in "Supported Platforms List" doc that:
Caution
Changing the number of virtual CPUs, the amount of virtual RAM, or the number or size of virtual disks is not supported.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/11x/supported_platforms/b_11xcucspl.html
What is the best practice to increase resource in this VM's?
Asaf Goldberg
Hi all,
To the Unity Connection servers - I will backup and restore to a new OVA.
To Im&Presence Server - I look in the Cisco Docs, I saw a Procedure in "Upgrade and Migration Guide":
- To change the vCPU, make the change in vSphere Client. Ensure that you change the reservation value to match the specifications of the new release.
- To change the vRAM, make the change in vSphere Client. Ensure that you change the reservation value to match the specifications of the new release.
- To increase the vDisk space, edit the storage size using vSphere Client. If the virtual machine has two disks, expand the second one.
Link:
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/upgrade/11_5_1/cucm_b_upgrade-guide-cucm-115/cucm_b_upgrade-guide-cucm-115_chapter_0101.html#task_2BBF0452947C06D45098CCF473E496CB
Update:
I Backed up and restore the Unity, and Increae the Resource on Vsphere cliect to Presence Servers - it's work perfect.
Asaf Goldberg
Anthony Holloway
Whenever you need to adjust the OVA deployment, you can always perform a DRS backup of the application, deleted the VM from ESXi, and rebuild the entire server with the new OVA template and size, finishing with a restore from the DRS backup.
Here is the process documentation for DRS Backup/Restore in CUC.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/11x/install_upgrade/guide/b_11xcuciumg/b_11xcuciumg_chapter_01.html
Hi Anthony,
There is another way? Like shutting down the VM, Change VM settings and starting the VM?
Asaf Goldberg
Hi all,
Link:
Update:
Asaf Goldberg
