ā06-26-2013 09:58 AM - edited ā03-19-2019 06:54 AM
Dear Guys;
I have two concern about integration between CUCM and CUP
First one :
I am testing on CUCM 9.0 and CUPS 9.0 demo version, after configure all things, I cant found Capabilities Assignment on call manager, and I don't know how to assign user to CUP, CUPS. and is working on demo version or not??
Second one:
when we make a integration between CUCM 8.6 Licence and CUP 9.0, after configure Call Manager and go to start configure CUP the message appeared on CUP, "" there is a version mismatch with CUCM, ......, Both version must match before deployment can continue"". how can do it or its must to upgrade CUCM from 8.6 to 9.0 ???
thanks.
BR
ā06-26-2013 11:02 AM
You need to build UC services and service profiles under user management, then assign the profile to the end users and select the enable checkbox.
Chris
ā06-26-2013 11:20 AM
Please remember to rate helpful responses and identify helpful or correct answers.
ā06-28-2013 11:35 PM
thanks Dears;
after read cisco document ID:113458 and do all steps I am found some of steps not found in CUCM 9.0, So that if any one have document how to do integration CUCM 9.0 with CUPS 9.0 please tell me where can I found it.
thanks for your help.
BR
ā06-29-2013 05:20 AM
Here is the deployoment guide for version 9.1
HTH, please rate all useful posts!
Chris
