Integration of Unity 9.x with Avaya CM6
rodoneal09
I have a client that would like to migrate off of their present Avaya Voicemail system to a Unity Connection 9.X.   I am trying to find information on the integration and what hardware I would need to do the integration.   I say a few that talked about PMIG on older Avaya system.   Would I still need to do the PIMG integration with a Avaya CM6 and Unity Connection 9.X voicemail system?   Also would I have any limitation?    Thanks!
Tommer Catlin
PIMG or TIMG might be your safest bet.  Now, you could do a quick test of SIP trunk from the Avaya to Unity Connection.  It may or may not be supported, but could work.
PIMG/TIMG is for integrating 3rd party PBX with UCXN, to integrate Avaya VM to UCXN you can use VPIM integration.
Chris
