International Dial Plans for CUCM 8.5
grahamhopkins
Anyone know if there are specific files (I need the UK plan) for CUCM 8.5, the latest I can find on software download are all 7.x
Will these work ?
dakeller
Graham,
The 2.x IPD files were version specific (so for 6.x versions).  But the dial plans under 7.x are not version specific.  Cisco may update an IDP file when it needs to, but you can install the IDP files for the 7.x on 8.x.
Dan Keller
Technical Marketing Engineer
dakeller
Graham,
Dan Keller
Thanks Dan,
I can confirm I used the 7.x GB Plan and it works OK
Graham
Hi Graham
What version did you use? I've tried 3-1-9 and it didn't take!
Barry
