Intradomain Federation same domain name
thorstenn
Level 4
Level 4
is it possible to enable lync <=> jabber federation if lync users and jabber users have the same domain?
Lync domain = corporate.net
Presence domain =  corporate.net
Cheers
T
Chris Deren
Yes, this is supported as of version 8.6 I believe, it is called inter-domain federation and there is a doc on this topic on CCO.
HTH,
Chris
Chris Deren
HTH,
Chris
Hi Chris,
thx. You are absolutely right. I saw this document but interpret it wrong. :-)
am looking for the same, but cannot find the document.
can you point me to it ?
I use 9.1
