IPFaxService stops forwarding inbound faxes
drees
The Fax service started showing errors processing inbound fax messages. Here's the content from the last interation of the service. Any ideas?
"2004-12-16","20:56:21","Logging on to mailbox [MKT_NT_FS3\ufax]"
"2004-12-16","20:56:24","Processing inbox, message count= 3"
"2004-12-16","20:56:24","Attempting to get local sub via primary fax number"
"2004-12-16","20:56:24","Message delivered: Fax for posler, mailbox ID [ 7815 ] from [ Unknown ] -- Subject= Inbound FAX message [DNIS=7815]"
"2004-12-16","20:56:24","Caught COM exception trying to resolve recipient posler - Code: 0x80040ce8. Method: CIpFaxCdoHelper::ForwardMessage. [IpFaxMessageHelper.cpp::2118]"
"2004-12-16","20:56:24","Caught exception - Code: 0x800445ed. Method: CIpFaxCdoHelper::ForwardMessage. [IpFaxMessageHelper.cpp::2139]"
"2004-12-16","20:56:24","ForwardMessage() failed - Code: 0x800445ed. Method: CIpFaxCdoHelper::ForwardCurrentMessage. [IpFaxMessageHelper.cpp::1873]"
"2004-12-16","20:56:24","ForwardCurrentMessage() failed - Code: 0x800445ed. Method: CIpFaxCdoHelper::ProcessFaxInbox. [IpFaxMessageHelper.cpp::416]"
I can't find any references to this error message.The version is 2.0.0.17
Thanks.
5 Replies 5
lindborg
The latest version is 2.0.0.22 - probably worth making sure you give that a try. I'll forward along the log output anyway.
k.wiebe
Has the fax service been delivering inbound faxes correctly up until this error occured? Has the intended recipient of this fax message (posler) previously received an inbound fax successfully? Is user posler hidden from address books in Exchange, or is there anything different about this user?
It might be helpful to catch an occurance of this failure with the ip fax service diagnostics cranked up.
You can add this DWORD registry value, set it to 3, and let the service make a pass through the ip fax inbox, to get a much more detailed diagnostic trace:
HKLM\Software\Active Voice\IpFaxRouter\1.0\DiagLevel
Remove the registry value or set it to zero to disable the advanced diags once you've catpured them.
I upgraded to 2.0.0.22 and looks like I get the same results.
"2004-12-17","17:47:11","CIpFaxInboundRouter::MonThreadProc() start"
"2004-12-17","17:47:11","Logging on to mailbox [MKT_NT_FS3\ufax]"
"2004-12-17","17:47:14","Processing inbox, message count= 3"
"2004-12-17","17:47:14","Attempting to get local sub via primary fax number"
"2004-12-17","17:47:14","Message delivered: Fax for posler, mailbox ID [ 7815 ] from [ Unknown ] -- Subject= Inbound FAX message [DNIS=7815]"
"2004-12-17","17:47:14","Caught COM exception trying to resolve recipient posler - Code: 0x80040ce8. Method: CIpFaxCdoHelper::ForwardMessage. [IpFaxMessageHelper.cpp::2207]"
"2004-12-17","17:47:14","Caught exception - Code: 0x800445ed. Method: CIpFaxCdoHelper::ForwardMessage. [IpFaxMessageHelper.cpp::2228]"
"2004-12-17","17:47:14","ForwardMessage() failed - Code: 0x800445ed. Method: CIpFaxCdoHelper::ForwardCurrentMessage. [IpFaxMessageHelper.cpp::1962]"
"2004-12-17","17:47:14","ForwardCurrentMessage() failed - Code: 0x800445ed. Method: CIpFaxCdoHelper::ProcessFaxInbox. [IpFaxMessageHelper.cpp::456]"
Here's the contents from the diag file
17:44:55:134,-1,-1,-1,-1,LogMgr,-1,diag Diag file opened 2004-12-17 17:44:55
17:44:55:134,AvDiagnostics_MC,1152,3856,-1,,-1,-1,,D:\CommServer\Logs\diag_IpFaxConfig_20041217_174455.txt
17:44:55:135,CiscoUnity_LogMgr,1004,3856,-1,,-1,-1,IpFaxConfig,D:\CommServer\Logs\diag_IpFaxConfig_20041217_174455.txt
17:44:55:150,AvDiagnostics_MC,1141,3856,-1,,-1,-1
17:44:55:151,AvDiagnostics_MC,1142,3856,-1,,-1,-1
17:45:39:024,-1,-1,-1,-1,LogMgr,-1,diag Diag file closed 2004-12-17 17:45:39
The logs above were with the DWORD DiagLevel added with value of 3.
Could this happen if the customer changed a domain policy. Isn't this a problem with the service talking to the Exchange message store?
The only diag file of interest at present is the first one you attached. It doesn't look like it's got anything more than the first version, so I'm skeptical that the enhanced diags are activated.
The error is being generated during the creation and addressing of the message. In particular, when the intended recipient is added to the message, we try to resolve the recipient to make sure it's valid. That process is failing. It's not necessarily telling us the recipient is invalid, but the check is failing to return a useful result.
Does it fail for every recipient or just the one shown in the logs (posler)?
I just test another recipient and it appears to have processed that one since it just says delivered, then it starts failing again on posler who has 3 faxes. They must have changed something with this exchange account as it's been working.
