IPT Cluster - Part Number require
alanscosta
Dear,
I am a Project Manager of a IPT Cluster Project and would like to get some help find Part Number that i need to buy. I have to built a cluster with those informations:
Cluster:
02 - C210 with CUCM 8.5 (Publisher/Subscriber)
01 - Attendant Console Server (It must be running on the same C210) + 01 Client
01 - Unity (250 Mail Box running in the same C210)
I´ve found easily the Part Number for the Voice Gateway and Hardphones, but is a little complicated to find the P/N for those above. Can someone help me?
Best wishes
Yes assuming you have the vCPU to support it. The OVA decide that piece and you should have the space for these applications.
Srini
Steven DiStefano
My company has Solution Architects that can design this for you if your interested. We also have IPT Engineers that perform the implementation as well. If interested, let me know your geography...
Steve DiStefano
    • Sent from my iPhone. Excuse brevity and typographical errors. **
Sorry Steve, but i just need the part numbers. I need Cisco help to find those part numbers.
Att,
Can i install CUCM 8.5, Unity and Attendent Console in the same C210?
Srini
