Is it possible to map speed dial to "call forward" softkey????
Dear All,
Could please guide me here...
is it posible to map speed dial to call forward softkey???
If possible, please let me know the procedure....
Thanks in advance!!!!
Anthony Holloway
Are you asking, that if you had a speed dial line appearance on the phone today, could you use that speed dial as the destination for a CFwdAll?  Then the answer is yes!  Just press CFwdAll softkey, then press the speed dial.
If you are asking for something else, please clarify your question.  Thanks.
I believe he's asking about creating a softkey which combines CFA + DN in just one softkey, if so, that's not possible.
The alternative has already been given. Press CFA and then press speed dial.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
