Is it possible to reset 100 phones in CUCM
project.apksite
Hi all, I wanted to know if you could help me with a problem. My company has 15000 phones in one cluster and we want them muted until only 8851 type devices can hear their ringtone by applying this change via Common Phone Profile- without actually performing any configuration changes on each individual device! Then for those who can't be reset remotely (like myself), there should've been an option at some point where users themselves would have had full control over what sound they heard when someone called through our system - but alas now it doesn't seem possible anymore because of something that happened last week. We're pretty sure every person working here knows how important these details are so hopefully somebody will Answer this
Not sure what you really ask about, but if your asking if you can search for something that gives you X number of phones and then reset them the answer is yes that can be done.
Response Signature
Is it possible to reset 100 phones in CUCM:- Yes its possible.
But not clear with  the rest of the OP.
Response Signature
luciKet
Is it possible to reset 100 phones in CUCM? YES possible Best Skateboard For Commuting
TONY SMITH
In addition to the suggestions, you can program a timed BAT job to reset phones.  For example you could create one to reset each device pool, timed 10 minutes or so apart.  I presume your original question was to avoid hitting the cluster with 15,000 phones all registering at once.
