ISM-SRE-300-K9 & Cisco Configuration Professional Issue
Barry Richey
hi there,
i have a cisco 2901 router running CME 8.6 the router has a ISM-SRE-300-K9 card init with Unity Express 8.0.5 installed.
i am having issues with Cisco configuration professional and configuring the module
under module configuration the status is "module is not reachable", if i click on details i get further information "unable to execute command from the module. module is either reloading or is in failed state. you must make the module up and refresh the module"
i have tried reloading, resetting and refreshing the module but the issue is still present
i have accessed the module from the CLI set it in offline mode and factory defaulted it and the same issue is still present
the only thing i can think is that this is a bug with CCP as the loopback interface which the module is using can be pinged fine from the router so the message makes no sense.
any ideas
paolo bevilacqua
Is you problem with CCP or the module itself ?
Because, CCP bugs and limitations aside, the module can be normally be installed, configured and managed using CLI or its web interface (after software is initially loaded).
