ISR 4000 encrypted sip trunk
quevedo_lopez
Hi everyone,
I'm trying to setup correctly a encrypted sip trunk between a CUCM (12.5.1.11900-146) and a ISR4331.  I have configured a PKI structure with a SUB and ROOT CA.  The dial-peer on the router side brings up almost intermediately but on the CUCM side the sip trunk takes 6 hours and 30 minutes approximately, after this time if i reset the trunk, ups almost immediately, if i reset the router also the trunk ups very fast.  I had the same scenario with a couple with ISRG2 but no trouble to up at the first time.
This is the config for more info.
crypto pki trustpoint SUBCA
enrollment mode ra
enrollment url http://192.168.2.3:80/certsrv/mscep/mscep.dll
fqdn none
ip-address none
subject-name CN=ISR-4K
revocation-check none
source interface GigabitEthernet0/0/0
rsakeypair ISR-4K
crypto pki trustpoint ROOTCA
enrollment mode ra
enrollment url http://192.168.2.6:80/certsrv/mscep/mscep.dll
voice service voip
ip address trusted list
ipv4 192.168.2.0 255.255.255.0
ipv4 192.168.100.0 255.255.255.0
mode border-element
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
early-offer forced
dial-peer voice 1000 voip
description CUCM - PUBLISHER
destination-pattern [1-9]...
session protocol sipv2
session target dns:cucm125lab.labtest.local
session transport tcp tls
voice-class codec 1
voice-class sip options-keepalive
voice-class sip bind control source-interface GigabitEthernet0/0/0
voice-class sip bind media source-interface GigabitEthernet0/0/0
dtmf-relay rtp-nte
srtp fallback
no vad
dial-peer voice 1001 voip
description CUCM - SUBSCRIBER
preference 1
session target dns:cucm125sub.labtest.local
voice-class codec 1
dtmf-relay rtp-nte
srtp fallback
no vad
sip-ua
transport tcp tls v1.2
crypto signaling remote-addr 192.168.2.0 255.255.255.0 trustpoint SUBCA
Thanks in advanced.
quevedo_lopez
Update in this case!
I've just do this
Change the trustpoint on SIP-UA configuration to
sip-ua
crypto signaling remote-addr 192.168.2.0 255.255.255.0 trustpoint ROOTCA
Then i got this msg error "CRYPTO_OPSSL: Can't find router cert"
Then go back and config back the previous trustpoint
And the SIP TRUNK goes up on the CUCM side.
I've tested this condition changing the IP and hostname DNS a regenerating a new certificate and get the same results every time.  Could this be associate to a IOS or CUCM bug ? The Router version is 16.12.04.
Thanks in advanced.
