ISR 4331 replacement
Yangjp715
Level 2
Level 2
Hi all,
We have some ISR4331s with FXO or PRI at our branches acting as a voice gateway only. Now we are planning to replace them since ISR4k is eol, but have not found the replacement in the announcement. Any suggestion? Can i use ISR890 for those small branches? There are around 10-30 employees per each office.
6 Replies 6
There is no EOS or EOL announced for 4k.
Response Signature
As Nithin wrote there are no EOL notice for the ISR4K platform. Where have you got that information from?
Response Signature
Danny Eaton
I found it here
https://www.cisco.com/c/en/us/products/collateral/routers/4221-integrated-services-router-isr/eos-eol-notice-c51-742328.html
Table 2.       Product Part Numbers Affected by This Announcement
End-of-Sale Product Part Number
Product Description
ISR4221-B/K9
Cisco ISR 4221 High BW (2GE, 2NIM, 4G FLASH, 4G DRAM, IPB)
ISR4321-B/K9
Cisco ISR 4321 (2GE, 2NIM, 4G FLASH, 4G DRAM, IPB)
ISR4331-B/K9
Cisco ISR 4331 (3GE, 2NIM, 1SM, 4G FLASH, 4G DRAM, IPB)
This notice is only for a specific bundle “ISR4000 Series Boost Bundle Products”.
Response Signature
Danny Eaton
It's coming for the 4331 line this year.  One of the companies I work for was told to look at the 8000 series as a replacement, but our SDWAN templates and design are based on the 4331's.
https://www1-realm.cisco.com/c/en/us/products/collateral/routers/1000-series-integrated-services-routers-isr/eos-eol-notice-c51-742343.pdf
End-of-Sale Product
Part Number
Product Description
C1111-4P-SPM ISR 1100 4 Ports Dual GE WAN with SD-WAN Promo Support
C1111-4PLTEEA-SPM ISR 1100 4 Ports Dual GE WAN LTE Adv w/ SD-WAN Promo Support
C1111-4PLTELA-SPM ISR 1100 4 Ports Dual GE WAN LTE Adv w/ SD-WAN Promo Support
C1111X-8P-DNA-PM ISR 1100 8 Ports 8G Dual GE WAN with DNA Support
ISR4331-SPM Cisco ISR 4331 (3GE, 2NIM, 1SM) w/ SDWAN Promotion
ISR4331-SPM-8G Cisco ISR4331 (3GE, 2NIM, 1SM) w/ 8G + SDWAN Support
MEM4300-4GU8G-P 4G to 8G DRAM Upgrade (Promo) for Cisco ISR 4330,4350
MEM4320-4GU8G-P 4G to 8G DRAM Upgrade (Promo) for ISR4320
Those specific SKUs are from what I can tell for SDWAN bundles. Do you have any specific information on EOL notice for the 4K platform in general?
Response Signature
