Showing results forĀ
Search instead forĀ
Did you mean:Ā
Issue with incoming calls to CUCM through BRI
toekon1988
Hello!
I have an issie  with connecting cisco 2901 to Siemens HiPath through BRI. Cisco router is connected to CUCM through MGCP. Outcoming calls work properly, but incoming calls from HiPath fail. Debug q931 shows only this:
Aug 3 14:37:52.240 MSK: ISDN BR0/1/0 Q931: RX <- SEGMENT pd = 8 callref = 0x000E
Segmented Message i = 0x8105
1st segment. Segments remaining : 1
Aug 3 14:37:52.304 MSK: ISDN BR0/1/0 Q931: RX <- SEGMENT pd = 8 callref = 0x000E
Segmented Message i = 0x0005
Segments remaining : 0
Aug 3 14:37:56.084 MSK: ISDN BR0/1/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x000E
Cause i = 0x80E6333033 - Recovery on timer expiry
Though, during outgoing call show this:
Aug 3 15:10:44.639 MSK: ISDN BR0/1/0 Q931: TX -> SETUP pd = 8 callref = 0x01
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x8A
Exclusive, B2
Calling Party Number i = 0x0081, '15376'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '15397'
Aug 3 15:10:44.715 MSK: ISDN BR0/1/0 Q931: RX <- CALL_PROC pd = 8 callref = 0x81
Channel ID i = 0xA98382
Exclusive, Channel 2
Aug 3 15:10:44.839 MSK: ISDN BR0/1/0 Q931: RX <- ALERTING pd = 8 callref = 0x81
Facility i = 0x9FAA068001008201008B0100A1150202EC3C06082B0C02885302010603050001000000
Protocol Profile = Networking Extensions
0x0100
0x820100
0x8B0100
0xA1150202EC3C06082B0C02885302010603050001000000
Component = Invoke component, Unsupported operation
Facility i = 0x9FAA068001008201008B0100A10F0202EC4B0201553006820406040840
0x0100
0x820100
0x8B0100
0xA10F0202EC4B0201553006820406040840
Facility i = 0x9FAA068001008201008B0100A11A0202EC5A020101A111040CCC4354C84D4F42204B2E422E020101
0x0100
0x820100
0x8B0100
0xA11A0202EC5A020101A111040CCC4354C84D4F42204B2E422E020101
Facility i = 0x9FAA068001008201018B0100A1550202EC6906082B0C0288530201003045810D0C0700803135333937740200C08234032000000410000000200000040400C00E380070032001020000830480050000878C6301C37C0D83CC4354C84D4F42204B2E422E
0x0100
0x820101
0x8B0100
0xA1550202EC6906082B0C0288530201003045810D0C0700803135333937740200C08234032000000410000000200000040400C00E380070032001020000830480050000878C6301C37C0D83CC4354C84D4F42204B2E422E
c2901-ges15-v-prim#
Progress Ind i = 0x8088 - In-band info or appropriate now available
c2901-ges15-v-prim#
Aug 3 15:10:53.499 MSK: ISDN BR0/1/0 Q931: RX <- CONNECT pd = 8 callref = 0x81
Facility i = 0x9FAA068001008201008B0100A1150202ECD206082B0C02885302010603050011800000
0x0100
0x820100
0x8B0100
0xA1150202ECD206082B0C02885302010603050011800000
Facility i = 0x9FAA068001008201008B0102A1520202ECE106082B0C02885302011B30423040A0088006313538353935A00BA1090404444543540201018327032500000400000000400000000400E00E38007F7F7F7F7B6F7F7F7F8104800500000004009080
0x0100
0x820100
0x8B0102
0xA1520202ECE106082B0C02885302011B30423040A0088006313538353935A00BA1090404444543540201018327032500000400000000400000000400E00E38007F7F7F7F7B6F7F7F7F8104800500000004009080
Facility i = 0x9FAA068001008201018B0100A1190202ECFF06082B0C0288530201003009810729051208030F09
0x0100
0x820101
0x8B0100
0xA1190202ECFF06082B0C0288530201003009810729051208030F09
Config of bri interface:
interface BRI0/1/0
no ip address
isdn switch-type basic-net3
isdn timer T310 60000
isdn point-to-point-setup
isdn incoming-voice voice
isdn bind-l3 ccm-manager service mgcp
static-tei 0
Show isdn status:
ISDN BRI0/1/0 interface
dsl 4, interface ISDN Switchtype = basic-net3
L2 Protocol = Q.921 0x0000 L3 Protocol(s) = CCM MANAGER 0x0003
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 4 CCBs = 0
The Free Channel Mask: 0x80000003
Can this issue be because of switch-type mismatch? Or Can be another problem?
0 Replies 0
