06-23-2021 08:52 AM
I have tried everything I know and I'm missing something. Still unable to get phones firmware to up load. I am able to get the phone to at least take part of the configure. Since I have to use the password to get into the phone. Only thing let is to have it display. any great wisdom. I have attached a few documents to show the firmware is in the TFTP server and the register global. Would to get this behind me and learn how to make this process quicker....
Thank you in advance for any advice....
06-23-2021 09:25 AM
From a working Environment.
CME running on ISR4k
tftp-server bootflash:kern2.78xx.12-7-1-0001-393.sbn
tftp-server bootflash:kern78xx.12-7-1-0001-393.sbn
tftp-server bootflash:rootfs2.78xx.12-7-1-0001-393.sbn
tftp-server bootflash:rootfs78xx.12-7-1-0001-393.sbn
tftp-server bootflash:sboot2.78xx.12-7-1-0001-393.sbn
tftp-server bootflash:sboot78xx.12-7-1-0001-393.sbn
tftp-server bootflash:sip78xx.12-7-1-0001-393.loads
tftp-server bootflash:boot1288xx.BE-01-007.sbn
tftp-server bootflash:fbi88xx.BE-01-012.sbn
tftp-server bootflash:kern88xx.12-7-1-0001-393.sbn
tftp-server bootflash:kern288xx.12-7-1-0001-393.sbn
tftp-server bootflash:kern388xx.12-7-1-0001-393.sbn
tftp-server bootflash:m0patch288xx.BE-01-001.sbn
tftp-server bootflash:preloader88xx.BE-01-002.sbn
tftp-server bootflash:rootfs88xx.12-7-1-0001-393.sbn
tftp-server bootflash:rootfs288xx.12-7-1-0001-393.sbn
tftp-server bootflash:rootfs388xx.12-7-1-0001-393.sbn
tftp-server bootflash:sb288xx.BE-01-026.sbn
tftp-server bootflash:sb2288xx.BE-01-013.sbn
tftp-server bootflash:sb2388xx.BE-01-027.sbn
tftp-server bootflash:sip88xx.12-7-1-0001-393.loads
tftp-server bootflash:ssb288xx.BE-01-007.sbn
tftp-server bootflash:vc488xx.12-7-1-0001-393.sbn
voice register global
mode cme
source-address X.X.X.X port 5060
timeouts interdigit 5
max-dn 100
max-pool 100
load 7841 sip78xx.12-8-1-0001-455
load 8841 sip88xx.12-7-1-0001-393
load 8851 sip88xx.12-7-1-0001-393
olsontimezone Asia/Muscat version 2018e
timezone 34
date-format D/M/Y
create profile sync 1506540522068233
auto-register
06-23-2021 10:45 AM
No this is not a working environment, it is a testing environment. I am trying to learn to set them up, so I can then take them to another router that is in a working environment and deploy them there.
Thanks again for taking the time to help...
06-23-2021 09:15 PM
I mean the above configuration which i shared is from a working customer site. Try the above.
Also make sure that the files are in the right folders.
06-24-2021 07:46 AM
Ok making some progress, at least now. When I go into Phone information I see the upgrade failed and the old firmware is still there but when I go to show details it has the current firmware visible and above it says inactive cmterm-88xx-14-0-1-0101-145
