IVR disconnection issue
mferhai
Dear Cisco Support,
I have a CUCM6.0 server with IVR 5.0 integration.
I have an issue when calling Cisco IVR..in deed, IVR doesn't disconnect the call once we hungup the call from internal/external.
Can you please give me some clues to fix it
Many Thanks
MF
Jonathan Schulenberg
What IVR product are you using? IP IVR, UCCX, CVP, etc?
If you are using UCCX/IP IVR then you need to add an On Exception (contactInactiveException) step to your script. A script won't watch for caller abandonment unless you tell it to.
Example:
Start
Accept
On Exception (contactInactiveException) GoTo END
...script logic...
Terminate
LABEL: END
End
Note: Do NOT allow the exception to process any other steps besides End without a Clear Exception step. Doing so will cause an exception loop.
