IVR TCL problem on a 1760
c.stamataras
Hi all.
I have a 1760 (c1760.entservicesk9.12415T4) on which I have loaded a WORKING config AND audio files from a 2811.
Athough the sh call appl sess shows the sessions running and all functionality of the tcl works fine, the audio is never heard. I even opened the moh file, re-recorded the voice and saved it changing only the name to the _welcome_ivr.au, still nothing.
Of course all mentioned files are in the flash and the voice port and the audio file are ulaw.
The config is:
voice-port 2/1
connection plar 900
caller-id enable
dial-peer voice 9000 voip
description ### Service IVR ###
service ivr
destination-pattern 900
session target ipv4:10.38.117.2
incoming called-number 900
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
application
service queue flash:app-b-acd-2.1.2.2.tcl
param queue-len 15
param aa-hunt10 100
param queue-manager-debugs 1
param number-of-hunt-grps 1
service ing flash:app-b-acd-aa-2.1.2.2.tcl
paramspace english index 0
param max-time-vm-retry 2
param voice-mail 100
param max-time-call-retry 300
param aa-pilot 900
param max-extension-length 3
paramspace english language en
param dial-by-extension-option 1
param handoff-string ivr
param welcome-prompt _welcome_ivr.au
paramspace english location flash:
paramspace english name ivr
param call-retry-timer 7
param service-name queue
param second-greeting-time 30
Any ideas why or what can be done?
Thnx, Chris
jamesfang98
1. 'service ing' need to be 'service ivr'
2. ouput your 'dir flash' result
yes, thanks but I had already changed it before posting it and still did not not work.
Is the 1760 capable of working with the scripts or there are some issues, limitations etc?
From IOS/CME compatible matrix, it should work for your version.
Ref:http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
Since your music not playing, what is your music file name in your flash? 'dir flash' can tell you.
finally I changed the IOS to c1700.ipvoicek9.124.15.T7 and it works fine without changing the config!
Looks like there was a bug on the enterprise services ios...
Thanks everyone for their help!
