LDAP connection error
Fred Rawlings
I have a 2008 domain controller that I'm trying to configure the LDAP directory with CUCM 8.5, I keep getting the following error message when saving,
Error while Connecting to ldap://xxx.xxx.xxx.xxx:389, null
We do have this setup with another domain controller and it's been working fine, the reason for setting this up on another is because we have another domain that we're going to move everything over
current domain - xy.com
new domain - corp.xy.com
I basically took the current settings from the CUCM with the current domain controller, created a new and copied, replacing the fields with the settings of the new domain controller.
Current settings
LDAP Configuration Name: XY Users AD
LDAP Manager Distinguished Name: CN=Call Manager LDAP Sync,OU=Admins,DC=xy,DC=com
LDAP User Search Base: OU=xy users,DC=xy,DC=com
LDAP Server Information: xxx.xxx.xxx.xxx:389
Settings on the new domain controller
LDAP Configuration Name: Corp XY users AD
LDAP Manager Distinguished Name: CN=Call Manager LDAP Sync,OU=Admins,DC=corp.xy,DC=com
LDAP User Search Base: OU=xy users,DC=corp.xy,DC=com
LDAP Server Information: xxx.xxx.xxx.xxx:389 (IP of the new domain controller)
Did I miss a step anywhere? Any ideas would be greatly appreciated.
Tommer Catlin
Correct me if Im wrong here but:
Should be:   OU=XY users, DC=CORP, DC=XY, DC=COM
You cant have corp.xy
But, just to double check if you can bind to LDAP using a tool such as Softera:
http://www.ldapbrowser.com/download.htm
You can verify if its a context naming issue or Controller issue or CUCM issue.   I always use Softtera first.  If it works with the bind name and OU, then I go to CUCM and configure it.
Tommer Catlin
