LDAP OU Limitation on CUCM10.5?
HUI YI CHEN
Hi Guys,
Anyone knows LDAP OU limitation on CUCM 10.5? I couldn't find any document referring to CUCM10.5. I remember LDAP OU can only up to 5 on CUCM8.X.
Any changes on CUCM10.5?
Cherry
testeven
Hi Cherry,
If you refer to the 10.X SRND you'll see the maximum number of synchronization agreements has changed to 10 instead of 5.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/collab10/collab10/directry.html#pgfId-1084415
Hole this helps!
Tere.
Please rate useful posts!
Regards, Tere. If you find this post helpful, please rate! :)
[+5] to Tere for sharing the info.
regds,
aman
