Let's Encrypt with MRA registered devices
Is it possible to use ACME services for Let's Encrypt certificates in Expressway with remote registered devices, for example 88xx?
We run X12.5.6 and CM 12.5.1.12016-3 with latest available device pack installed 12.5.1.12013-1.
When I try this I get an error about that the domain can't be verified.
Any help on this is highly appreciated.
Response Signature
See this bug
78xx/88xx CA Trust List: Inclusion of Letsencrypt X1 root CA cert
CSCvk66432
and also read this
https://letsencrypt.org/certificates/
java
if this helps, please rate
6 Replies 6
cgmiller913
You have to add A records on the public domain you are using for the CN and SANs you are using in the cert.
-Chris
I think that applies to the actual setup of the ACME service in the E MRA. That part is completed and we can connect Jabber clients via the MRA with no problem. However on a desk phone we get an error message about certificate of domain can’t be verified.
Response Signature
See this bug
CSCvk66432
and also read this
java
Thanks Java!
Response Signature
Hi Jaime,
is there any update to this Bug if Lets Encrypt will stop supporting DST Root X3 in September 2021?
Thank you!
Vit
Maybe best if you post your own question as your question is not really related to the OP and this post has been marked as answered.
Response Signature
