12-20-2019 06:58 AM
Is it possible to use ACME services for Let's Encrypt certificates in Expressway with remote registered devices, for example 88xx?
We run X12.5.6 and CM 12.5.1.12016-3 with latest available device pack installed 12.5.1.12013-1.
When I try this I get an error about that the domain can't be verified.
Any help on this is highly appreciated.
Solved! Go to Solution.
12-20-2019 10:15 AM
See this bug
78xx/88xx CA Trust List: Inclusion of Letsencrypt X1 root CA cert
CSCvk66432
and also read this
https://letsencrypt.org/certificates/
12-20-2019 09:04 AM
You have to add A records on the public domain you are using for the CN and SANs you are using in the cert.
-Chris
12-20-2019 09:31 AM
12-20-2019 10:15 AM
See this bug
CSCvk66432
and also read this
12-20-2019 10:17 AM
01-11-2021 07:07 AM
Hi Jaime,
is there any update to this Bug if Lets Encrypt will stop supporting DST Root X3 in September 2021?
Thank you!
Vit
01-11-2021 07:56 AM
Maybe best if you post your own question as your question is not really related to the OP and this post has been marked as answered.
