Logging issue cucm 9.1.2.12900-11
waqas sardar
Guys,
We are facing issue with logging or some time with the attached error.
System version: 9.1.2.12900-11
Please advise solution
Aman Soi
Hi Waqas,
seems to be database replication issue.
you can run utils dbreplication  runtimestate from putty and check for replication state. Ideally,it should be 2 which means replication is good
https://supportforums.cisco.com/document/52421/troubleshooting-cucm-database-replication-linux-appliance-model
regds,
aman
Manish Gogna
For this specific error you can follow the instructions as per the following doc
https://supportforums.cisco.com/document/113936/database-communication-error-when-logging-cisco-unified-communications-manager
Manish
