Looking for UCSInstall_UCOS_8.6.2.22900-9.sgn.iso
JChen522
Hi we have an old CUCM that is running 8.6.2.22900-9
The CDs we have is 8.6.1.20000-1
We are trying to reinstall and restore from backup.  However, it is not recognizing the backup probably because of the version difference.
Does anyone know where I can obtain this file? UCSInstall_UCOS_8.6.2.22900-9.sgn.iso
I tried searching on the Cisco support website but it is not there any more.
Really appreciate any help!
Thank you!
17 Replies 17
Jaime Valencia
You can only restore on the exact same release from which you took the backup, that is explained in the DRS guide, so yes, that's why you cannot restore on the version you installed.
8.x is EOL/EOS and that's why it was removed from downloads.
Right now google is going to be your best friend trying to find it, you can try your SE as a best effort resource as the product has been EOL/EOS for some time.
java
if this helps, please rate
Thank you for the quick respond.
If I do find it on the web, once I download it, how do I update it from 8.6.1.20000-1 to 8.6.2.22900-9?  Do you know where I can find the instruction?
Really appreciate your help!  Thank you!
This would be a normal standard minor upgrade. You would do the upgrade just as with any other version. If you do not know how to it would be advisable to seek help with this from a reputable Cisco partner with the required specialisation.
Response Signature
I have a copy of this if you are still looking for it.
I was able to recover the one in production.  Thanks for your help!
hi stephenepley6314 ,may i have a copy?tks!
Thank you very much!Do you have a Chinese language pack for it?
One more request, do you have the latest SIP firmware for the 7970 phone? The file name is cmterm-7970_7971-sip.9-4-2SR3-1.zip
Let me check tomorrow.
I do not have any additional language packs or the 7970 firmware files sorry.
Thanks a lot^_^
Hi stephenepley6314,
Could you please fix your google drive link as it currently says access denied. Many thanks in advance
Link should be active again at this time.
Thank you so much!
