VOICE TRANSLATION RULE QUESTION
akamps
Hello Community,
Assistance is needed in voice translation rule on Cisco Cube.
I wish to transform the number +256312900045 to 0045. The 0045 is an extension and former is coming from the ITSP.
8 Replies 8
voice translation-rule 1
 rule 1 /^\+25631290\(0045\)$/ /\1/
Response Signature
Hello Roger,
I tried this using
rule 1 /^\+25631290\(....\)$/ /\1/
And it didn't work
Did you put the translation rule into a translation profile and set it to translate the number you want to change and then put the profile to be used on a dial peer or voice port?
Response Signature
Yes I sure did. Do you mind if I share my config
Go for it. Please share it in a text file that you attach to your reply.
Response Signature
You can also test your translation rule with this command, test voice translation-rule <rule #> +256312900045.
Response Signature
The call might not be hitting the dial-peer where the translation is applied. Additionally, it might be applied in the wrong direction.
Please share the configurations that include the dial-peer and the translations so we can properly troubleshoot.
Response Signature
