10-15-2008 04:17 PM - edited 03-18-2019 09:49 PM
Is anyone know what is the maximum allowed connection on a single Meet Me Conference number?
Thanks.
Dat Pham
Solved! Go to Solution.
10-15-2008 04:35 PM
Hw= hardware
CFB = conference bridge
SW = software
java
10-15-2008 08:01 PM
Keep in mind that software conferencing will work only with G711 codec, and transcoders would be required to allow G729 streams to be mixed.
Alos, the default max meet-me participants number service parameter is 4, so you would have to change it to get your desired number.
Chris
10-15-2008 04:25 PM
if using SW CFB recommendation is not to go over 48 even though it lets you go as far as 128. if using HW CFB usually the limit will be 8.
java
if this helps, please rate
10-15-2008 04:29 PM
Thanks HTH,
Can you clarify on HW CFB and SW CFB? I am not familar with those?
Thanks.
Dat Pham
10-15-2008 04:35 PM
Hw= hardware
SW = software
java
10-15-2008 08:01 PM
Chris
10-15-2008 08:12 PM
Thanks Chris,
I will check on the service parameter setting.
Dat Pham
