Maximum Call Duration Timer in UCM
Hi;  any budy knows if the following service parameter in CM (Maximum call duration timer) works only with external calls (outgoing) or for any type of calls (internal, Outgoing, Incoming)
Juan Carlos Aleman
5 Replies 5
Kevin Roarty
Hi Juan,
This serivce parameters applies to all call types.
-Kevin
Hi Kevin,
How can I restrict outgoing calls only up to 30 minutes?
+Vladimir
Set the 'Maximum Call Duration Timer' CCM service parameter to 30
HTH.
Christian.
Thank you, Christian,
I mean, how to restrict outgoing calls only, but all incoming calls are to be without any limitations.
+Vladimir
You can create a TCL for that and apply it to the GW that connects the external call, please note TCL is not TAC supported.
HTH.
Christian.
