Maximum Length for SmartHost Unity Connection 10.5
mumbles202
Level 5
Level 5
What is the maximum length for the smarthost field in Unity Connection?  I'm trying to use a FQDN that points to a Office365 name, but the FQDN gets cutoff before the end when I save.  It works without any issue when I just add the ip address but I'd prefer to use the FQDN if possible in case it changes in the future.
Brandon Buffin
Looks like the limit is 40 characters. Definitely would be nice if the interface either stopped you from entering more than 40 or at least warned you of the limit.
Brandon
Brandon Buffin
Brandon
Ok thanks.  A little shorter than i needed so I'll stick with the IP for now.
