MCS-7845-H2-CCX2 for Unity 7.x
thomuff
Level 3
Level 3
Is it possible to use a MCS-78945-H2-CCX2 for Unity 7.x?
There was an ordering mixup and it is too late to return the server so can I repurpose it for Unity?
What are my options besides UCCX?
thomuff
Level 3
Level 3
MCS-7845-H2-CCX2
No, you can't use it for Unity.
Cisco Unity Supported Platforms List
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps5745/ps2237/product_data_sheet0900aecd802132ef.html
According to this link it's either UCCX or IP IVR what you can use it for.
Cisco MCS 7845-H2
http://www.cisco.com/en/US/partner/prod/collateral/voicesw/ps6790/ps5748/ps378/product_data_sheet0900aecd80587390.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
