MCS7816I5-K9-CMD2
159536
is there any replacement model for this?
Jaime Valencia
Not really, that was a bare metal server and currently most products only work over ESXi, and you can buy either a UCS or any 3rd party server that meets the requirements for the products you want to use.
java
if this helps, please rate
Jaime Valencia
java
159536
thanks
