05-18-2021 02:29 AM
is there any replacement model for this?
Solved! Go to Solution.
05-18-2021 06:37 AM
Not really, that was a bare metal server and currently most products only work over ESXi, and you can buy either a UCS or any 3rd party server that meets the requirements for the products you want to use.
05-18-2021 06:37 AM
05-20-2021 03:07 AM
thanks
