MediaSense concurrent calls recording
Ajin Skariah
Can someone tell me how many concurrent audio calls can be recorded for a mediasense cluster with a primary and secondary server with 2vCPU and 6 GB RAM? I read in Cisco document that 200 concurrent audio calls can be recorded for 7vCPU deployment model, but noting is mentioned for 2vCPU and 6 GB RAM.
Manish Gogna
Hi Ajin,
For 7 vCPU deployment
Supported Capabilities
Physical Hardware Audio-Weight Media Streams Supported Per Note + Concurrent API Requests Supported per non-Expansion Node Max Call Arrival Rate per Node Max Nodes per Cluster Max Media Storage per Node Max Video Playback per Node Notes
UCS B/C or Specs Based 400 15 + 10 queued 2 per second 5 12 TB 40 (Ver 10.0)
For 2 vCPU deployment
UCS B/C or Specs Based 40 3 + 3 queued 20 per minute 2 7 TB +++ 2 (Ver 10.0)
SRE-910 60 3 + 3 queued 20 per minute 2 210 GB none Not supported with MediaSense 10.0 or higher
UCS-E 40 3 + 3 queued 20 per minute 2 400 GB or
700 GB ++
2 (Ver 10.0) See here for Supported CPUs - TechNotes
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/uc_system/virtualization/virtualization-cisco-mediasense.html
From above it appears that it will support at max 30 calls.
Manish
Manish Gogna
Hi Ajin,
700 GB ++
Manish
Thank you Manish...
