03-30-2017 12:13 AM - edited 03-19-2019 12:17 PM
Can someone tell me how many concurrent audio calls can be recorded for a mediasense cluster with a primary and secondary server with 2vCPU and 6 GB RAM? I read in Cisco document that 200 concurrent audio calls can be recorded for 7vCPU deployment model, but noting is mentioned for 2vCPU and 6 GB RAM.
Solved! Go to Solution.
03-30-2017 10:30 PM
Hi Ajin,
For 7 vCPU deployment
Supported Capabilities
Physical Hardware | Audio-Weight Media Streams Supported Per Note + | Concurrent API Requests Supported per non-Expansion Node | Max Call Arrival Rate per Node | Max Nodes per Cluster | Max Media Storage per Node | Max Video Playback per Node | Notes |
UCS B/C or Specs Based | 400 | 15 + 10 queued | 2 per second | 5 | 12 TB | 40 (Ver 10.0) |
For 2 vCPU deployment
UCS B/C or Specs Based | 40 | 3 + 3 queued | 20 per minute | 2 | 7 TB +++ | 2 (Ver 10.0) | |
SRE-910 | 60 | 3 + 3 queued | 20 per minute | 2 | 210 GB | none | Not supported with MediaSense 10.0 or higher |
UCS-E | 40 | 3 + 3 queued | 20 per minute | 2 | 400 GB or 700 GB ++ |
2 (Ver 10.0) | See here for Supported CPUs - TechNotes |
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/uc_system/virtualization/virtualization-cisco-mediasense.html
From above it appears that it will support at max 30 calls.
Manish
03-30-2017 10:30 PM
Hi Ajin,
Manish
04-02-2017 05:14 AM
Thank you Manish...
