Meetme question
cris_jimenez
Level 2
Level 2
Hello Folks,
Can you setup a password on the meetme conference?
can you use unity and use some call handlers or something ?
please advice
thanks
5 Replies 5
Jaime Valencia
no
the workarond is to use unity transfer options to reach the meetme and use supervised transfer asking the name and the having unity tell you who is trying to join, then you can accept or deny entrance. but there is really no way to set a pwd. you would need MPE for this feature.
java
if this helps, please rate
java
Hi Java,
I was wondering, since initializing meetme conference requires pressing MeetMe softkey button on the phone, how can make it work using Unity?
David
you can join a meeting via unity by just dialing the meet-me DN
but you CANNOT initiate one via unity
java
java
oh, do you mean just from the auto-attendant menu?
From a call handler if you have configured the meet-me DN as a subscriber or call handler.
If not from a System transfer handler.
Any way you can only join an already started meet-me
java
java
