07-27-2019 05:01 PM
Hello All,
I am a route switch engineer and my voice experience is a beginner, so would like to get some insights on how to migrate from Voice PRI/ISDN to SIP. We have Cisco 4331 CME (used virtual CUE OVA service container) router and Polycom phones. I have polycom phones setup with grabbing the config files from 4331 CME router flash. Polycom phones are registered already with Voice PRI and when I removed PRI T1 configuration they still are registered.
We would like to get ride of physical PRI lines and have our telephony service leverage the data circuit. We have a SIP carrier already providing the service and they shared all the creds to use.
Can you give me some pointers on 4331 router SIP configuration. Below is the config that I tested with.
Thanks a lot.
version 16.7
no service pad
service password-encryption
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname C2921
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
! card type command needed for slot/bay 0/1
logging queue-limit 10000
logging buffered 1000000
logging persistent
logging rate-limit 10000
no logging console
aaa new-model
aaa authentication login default group tacacs+ line enable
aaa authentication login securid group tacacs+ line enable
aaa authentication enable default group tacacs+ enable
aaa authorization exec default group tacacs+ if-authenticated
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 0 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting system default start-stop group tacacs+
aaa session-id common
no ip bootp server
no ip domain lookup
ip domain name msstore.microsoftstore.com
no ip dhcp conflict logging
ip dhcp excluded-address 10.x.x.x 10.x.x.x
ip dhcp pool voice
network 10.x.x.128 255.255.255.192
default-router 10.x.x.129
option 66 ascii tftp://10.y.y.20/POLYCOM
option 150 ip 10.y.y.20
subscriber templating
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
registrar server expires max 1200 min 300
localhost dns:sipcarrier.com
voice class codec 1
codec preference 1 g711ulaw
voice register global
mode cme
source-address 10.y.y.20 port 5060
max-dn 60
max-pool 60
authenticate register
create profile sync abdcefgh
auto-register
voice register dn 5
number 7020
allow watch
name ABCD 7020
label ABCD 7020
voice register dn 13
number 7030
allow watch
name EFGH 7030
label EFGH 7030
voice register dn 14
number 7031
allow watch
name EFGH2 7031
label EFGH2 7031
voice register dn 21
number 7050
allow watch
name IJKL 7050
label IJKL 7050
voice register dn 22
number 7051
allow watch
name IJKL2 7051
label IJKL2 7051
voice register dn 25
number 7060
allow watch
name Office 7060
label Office 7060
voice register dn 29
number 7070
allow watch
name Roaming 7070
label Roaming 7070
voice register dn 30
number 7071
allow watch
name Roaming 7071
label Roaming 7071
voice register dn 31
number 7072
allow watch
name Roaming 7072
label Roaming 7072
voice register dn 32
number 7073
allow watch
name Roaming 7073
label Roaming 7073
voice register dn 33
number 7074
allow watch
name Roaming 7074
label Roaming 7074
voice register dn 34
number 7075
allow watch
name Roaming 7075
label Roaming 7075
voice register template 1
dialplan 1
voice register dialplan 1
type 7940-7960-others
pattern 1 2...
pattern 2 7...
voice register pool 5
id device-id-name MACADDRESS1
type P600
number 1 dn 5
template 1
no digit collect kpml
dtmf-relay rtp-nte
voice-class codec 1
username 7020 password password
voice register pool 13
id device-id-name MACADDRESS2
type P600
number 1 dn 13
template 1
dtmf-relay rtp-nte
username 7030 password password
codec g711ulaw
voice register pool 21
id device-id-name MACADDRESS3
type P600
number 1 dn 21
template 1
dtmf-relay rtp-nte
username 7050 password password
codec g711ulaw
voice register pool 25
id device-id-name MAC ADDRESS4
type P600
number 1 dn 25
template 1
dtmf-relay rtp-nte
username 7060 password password
codec g711ulaw
voice register pool 29
id device-id-name WIRELESSSERVEMACADDRESS
number 1 dn 29
number 2 dn 30
number 3 dn 31
number 4 dn 32
number 5 dn 33
template 1
dtmf-relay rtp-nte
username 7070 password password
codec g711ulaw
voice hunt-group 1 parallel
list 7020,7025
pilot 7120
voice hunt-group 2 parallel
list 7030,7031
pilot 7130
voice hunt-group 3 parallel
list 7050,7051
pilot 7150
voice hunt-group 6 parallel
list 7070,7071,7072,7073,7074,7075
pilot 7171
voice hunt-group 7 sequential
final 7171
list 7050,7051,7020
timeout 12
pilot 7250
voice hunt-group 8 sequential
final 7050
list 7060,7070
timeout 40
pilot 7175
voice translation-rule 1
rule 1 /.+/ /PHONENUMBER/
voice translation-profile 1
translate calling 1
voice-card 0/1
no watchdog
voice-card 0/2
no watchdog
license udi pid ISR4331/K9 sn SERIAL
license accept end user agreement
license boot suite FoundationSuiteK9
license boot suite AdvUCSuiteK9
no license smart enable
diagnostic bootup level minimal
archive
log config
logging enable
redundancy
mode none
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface VirtualPortGroup0
ip unnumbered GigabitEthernet0/0/0
no mop enabled
no mop sysid
cdp enable
interface VirtualPortGroup1
no mop enabled
no mop sysid
cdp enable
interface GigabitEthernet0/0/0
description CTS to Core Switch 4/0/44
ip address 10.y.y.20 255.255.255.192
negotiation auto
interface GigabitEthernet0/0/1
description 4401 Gi0/0/3
ip address 10.99.1.2 255.255.255.252
negotiation auto
interface GigabitEthernet0/0/2
description 4402 Gi0/0/3
ip address 10.99.2.2 255.255.255.252
negotiation auto
interface Service-Engine0/1/0
snmp trap link-status permit duplicates
interface Service-Engine0/2/0
vrf forwarding Mgmt-intf
no ip address
negotiation auto
interface Async1/0/0
no ip address
interface Async1/0/1
no ip address
interface Async1/0/2
no ip address
interface Async1/0/3
no ip address
interface Async1/0/4
no ip address
interface Async1/0/5
no ip address
interface Async1/0/6
no ip address
interface Async1/0/7
no ip address
interface Async1/0/8
no ip address
interface Async1/0/9
no ip address
interface Async1/0/10
no ip address
interface Async1/0/11
no ip address
interface Async1/0/12
no ip address
interface Async1/0/13
no ip address
interface Async1/0/14
no ip address
interface Async1/0/15
no ip address
router eigrp 65499
network 10.99.1.0 0.0.0.3
network 10.99.2.0 0.0.0.3
passive-interface default
no passive-interface GigabitEthernet0/0/1
no passive-interface GigabitEthernet0/0/2
virtual-service vCUE
vnic gateway VirtualPortGroup0
guest ip address 10.y.y.14
vnic gateway VirtualPortGroup1
activate
ip default-gateway 10.y.y.1
ip forward-protocol nd
ip http server
ip http authentication aaa
ip http secure-server
ip http path flash:/GUI
ip route 0.0.0.0 0.0.0.0 10.y.y.1
ip route 10.y.y.14 255.255.255.255 VirtualPortGroup0
ip route 10.y.y.14 255.255.255.255 VirtualPortGroup1
ip tacacs source-interface GigabitEthernet0/0/0
ip ssh time-out 60
ip ssh authentication-retries 5
ip ssh version 2
ip scp server enable
tftp-server flash:POLYCOM/2345-12375-001.bootrom.ld
tftp-server flash:POLYCOM/2345-12375-001.sip.ld
tftp-server flash:POLYCOM/2345-12670-001.bootrom.ld
tftp-server flash:POLYCOM/2345-12670-001.sip.ld
tftp-server flash:POLYCOM/Answer_Desk_7030.cfg
tftp-server flash:POLYCOM/Inventory_7020.cfg
tftp-server flash:POLYCOM/Manager_Office_7060.cfg
tftp-server flash:POLYCOM/MSStore.jpg
tftp-server flash:POLYCOM/SIP.CFG
tftp-server flash:POLYCOM/SIP.VER
tftp-server flash:POLYCOM/MAC1.cfg
tftp-server flash:POLYCOM/MAC1-phone.cfg
tftp-server flash:POLYCOM/MAC2.cfg
tftp-server flash:POLYCOM/MAC2-phone.cfg
tftp-server flash:POLYCOM/MAC3.cfg
tftp-server flash:POLYCOM/MAC3-phone.cfg
tftp-server flash:POLYCOM/MAC4.cfg
tftp-server flash:POLYCOM/Store_SIP.cfg
tftp-server flash:POLYCOM/_7050.cfg
tftp-server flash:POLYCOM/MAC4-phone.cfg
control-plane
voice-port 0/2/0
connection plar 7010
shutdown
description 911 via
voice-port 0/2/1
signal loopStart live-feed
shutdown
description Muzak MOH
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
telephony-service
moh-file-buffer 2000
authentication credential cisco cisco
max-ephones 10
max-dn 20
ip source-address 10.y.y.20 port 2000
system message Microsoft Retail Store
url services http://10.y.y.20/
url authentication http://10.y.y.20/
load 7916-12 B016-1-0-3
load 7916-24 B016-1-0-3
load 7975 SCCP75.9-2-3S
time-zone 12
voicemail 2050
max-conferences 8 gain -6
moh enable-g711 "music-on-hold.au"
web admin system name cisco password cisco
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
create cnf-files version-stamp 7960 May 22 2017 18:11:19
dial-peer voice 2000 voip
description CUE Default AA
destination-pattern xxxxxxx
b2bua
session protocol sipv2
session target ipv4:SIP CARRIER PUBLIC IP
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 2010 voip
description CUE Greetings Admin
destination-pattern 2010
b2bua
codec g711ulaw
no vad
dial-peer voice 10 voip
description **Incoming Call from SIP Trunk**
translation-profile incoming CUE_Voicemail/AutoAttendant
preference 1
destination-pattern 2.........
incoming called-number .%
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
no vad
dial-peer voice 11 voip
destination-pattern .T
voice-class codec 1
dtmf-relay rtp-nte
no vad
num-exp 1603 7050
num-exp 1605 7030
num-exp 1604 7060
num-exp 1602 7020
num-exp 1601 7171
sip-ua
authentication username SIPPHONENUMBER password 7 sippassword
no remote-party-id
retry invite 2
retry register 10
timers connect 100
registrar dns:sipcarrier.com expires 3600
sip-server dns:sipcarrier.com
host-registrar
ephone-dn 1 octo-line
number 7010
label Operator
name Operator
call-forward all 7030
call-forward noan 7171 timeout 15
hold-alert 30 originator
ephone-dn 20
number 2555
moh out-call 5551212
end
08-05-2019 06:28 AM
Is this configuration working for you? If I understand correctly, you are looking for pointers for SIP configuration. Am I right?
08-05-2019 07:52 AM
Hello Vaijanath,
Thank you for the reply. No it is not working, I see some invite messages out to sip providers but the sip provider says that they see these messages but not the bindings.
Yes I am looking for pointers for SIP.
thank you
08-05-2019 09:08 AM - edited 08-05-2019 09:09 AM
Please check out this URL for detailed information on CME SIP Trunk configuration:
08-09-2019 12:13 PM
Thats the document that I used for my basic configuration.
Thank you
