Showing results forĀ
Search instead forĀ
Did you mean:Ā
modify de P-Asserted-ID.
victorls
Hello Everybody,  I will like to ask you something about CUBE and SIP parameters.
I send a call with P-Asserted-Identity: <sip:1001@131.X.X.X>
but my ISP is asking me to send de information in the next format
P-Asserted-Identity: <sip:1001@131.X.X.X;user=phone;cpc=ordinary>
I made many combinations but none results I get one like this one:
P-Asserted-Identity: <sip:1001@131.X.X.X>;user=phone;cpc=ordinary
but the ISP told me that is not accepted by his equipment.
I will be glad if someone can guide me to get the answer I have a cisco ASR1001 with IOS asr1001-universalk9.03.11.02.S.154-1.S2-std
regards.
victorls
I test some profiles but I only get the next modification
P-Asserted-Identity: <sip:1001@131.0.124.29>;user=phone
This is the configiration I use:
voice class sip-profiles 10
request INVITE sip-header P-Asserted-Identity modify "(.*)" "\1;user=phone"
but this is not working.
See if this helps
request INVITE sip-header P-Asserted-Identity modify "; SIP/2.0" ";user=phone SIP/2.0"
request RE-INVITE sip-header P-Asserted-Identity modify "; SIP/2.0" ";user=phone SIP/2.0"
request INVITE sip-header P-Asserted-Identity modify "; SIP/2.0" ";cpc=ordinary SIP/2.0"
request RE-INVITE sip-header P-Asserted-Identity modify "; SIP/2.0" ";cpc=ordinary SIP/2.0"
Abhay
Abhay Singh Reyal
The Only Way To Do Great Work Is To Love What You Do. If You Havenā€™t Found It Yet, Keep Looking. Donā€™t Settle
