MOH unicast audio stream
anas_darwesh
When we use uni-cast music on hold with call manager and we select the same device pool for endpoints ; we have found the continuing stream for last hold (initial hold)
when we start the second hold so; When we changed device pools (without any relations between regions ) we noticed a change stream for holds start from initial point for music
so; this solution doesn't logic with business area
What else can i do with these behaviors ?
Maybe it is just me, but I’m sorry as I don’t understand one thing of what you’re writing. Would you please mind to rephrase and explain a little bit better?
Response Signature
