07-11-2021 01:38 AM
Does anyone knows if there is differences between MRA for windows and MRA for mobile phone like android in terms of jabber software requirements and implementation.
I configured several times MRA for jabber windows.
07-11-2021 01:44 AM
MRA is mobile and remote access feature. There is nothing called MRA windows and MRA mobile device.
when you configure Jabber, you need to configure as CSF for laptop. BOT for android, TCT for iPhone.
07-11-2021 06:48 AM
Yes I know that. Some Telepresence endpoints such as DX EX or MX support also MRA.
07-11-2021 06:54 AM - edited 07-11-2021 06:55 AM
Over MRA Are you trying to register devices or jabber client, can you explain a bit more about your requirement?
07-11-2021 07:10 AM
I am looking the differences between implementing Cisco Jabber for windows to use MRA and Cisco Jabber for android to use MRA.
07-11-2021 07:25 AM
When configuring jabber you need to configure windows jabber as CSF and android jabber as BOT. AFAIk thats the difference.
07-11-2021 11:11 AM - edited 07-11-2021 10:41 PM
There is no difference. The Jabber client, regardless of type, will do a service discovery to connect. If it finds the SRV record for MRA it would use it to connect, this should only be present in the external DNS zone, if it does not it would continue to do the service discovery for the internal SRV record, that should be present in the internal DNS zone.
For more details please see this presentation from Cisco Live. https://www.ciscolive.com/global/on-demand-library.html?search.event=ciscoliveemea2019&search.featured=cloSessionsWithVideo&search.technology=scpsTechnology_collaboration&search=Troubleshoot%20Jabber#/session/1532112838864001tLPF
